Old 03-14-2008, 04:46 PM
Kyrasis6 is on a distinguished road
Send a message via AIM to Kyrasis6
Default Where to get Fiberglass Tape
Hey guys, someone on here had a lot of success insulating between panels using fiberglass tape, anybody know where I can get some? Doesn't need to have adhesive or anything, just need a roll or two 1-2" wide that I can lay out between the sheet metal.
Thanks,
K6
Old 03-16-2008, 07:28 AM
JTW37's Avatar
Caswell Platinum Member
Default Re: Where to get Fiberglass Tape
You using it as a gasket?
Old 03-17-2008, 08:38 AM
Sort of, but not for the door. I saw a post on here a while back where someone used fiberglass tape between the sheet metal and the studs to help with insulating. I'm looking for a way to reduce heat transfer from the studs to the outside skin.
Old 03-17-2008, 08:59 AM
JTW37's Avatar
You will get quite a bit of heat transfer to the skin regardless. My oven walls, away from the studs get warm to hot (around 100 deg). Depending where I lay my hand. It's hotter near the glass then on an area that only has the skin. But it don't really get that hot all over. Eastwood has Fiberglass tape that they sell for masking off parts to powder coat. Maybe that will work?
Old 03-21-2008, 06:21 AM
Fox Fox is offline
Fox is on a distinguished road
I wonder if aluminum tape would work better.
Old 03-22-2008, 07:06 AM
JTW37's Avatar
I have used the aluminum tape inside and I eventually had to take it out, as the heat melts the glue. But it did work for awhile. You putting it on the outside?
Old 03-22-2008, 05:53 PM
Fox Fox is offline
Me? Ya i was thinking of putting it over the sealant that cover the seams.
  #8 (permalink)
Old 03-23-2008, 06:37 AM
JTW37's Avatar
I was just curious. I'm sure on the outside, it should be fine. It's just the 400 + deg it don't like. How about some pics of the oven?
how many are using plain fiberglass insulation? defed Oven Building Forum 6 04-09-2007 08:51 PM
Fiberglass work Spiewaker Services Offered/Wanted 0 04-17-2006 05:10 PM
tape customandsound Powder Coating Questions 3 06-16-2005 09:41 AM
coating fiberglass jtagger19 Powder Coating Questions 9 12-16-2004 06:15 PM
chrome over fiberglass? Blademan Powder Coating Questions 3 06-20-2004 09:34 PM
