+ Reply to Thread
Results 1 to 5 of 5
Thread: Propane Oven - I know it's been asked
  1. #1
    Default Propane Oven - I know it's been asked
    I am the General Manager for Yesteryear Auto and RV Center and we are expanding our line of products to encompass off road vehichles and are going to produce our own line of dune buggies. I have seen booths that will just barely fit our frames in them that are 12K+. In doing research I stumbled onto this jewel of a site and I am hoping that I can get some questions answered.
    The oven I intend to build is approximately 7'H x 12'L x 12'W. According to the calculators on this site I will need approximately 108,000 BTU to heat this space to 450 degrees (with a tight seal). I saw on the same website as the calculator propane infrared/radiant heaters that put out 42,000 BTU. Would I be safe to assume that If I were to put 3 (126,000 BTU total) of these units inside a self built booth that I could would be able to attain appropriate temperatures to bake an entire dune buggy frame inside? Or am I oversimplifying the whole oven Idea.
    This is the heater element I am talking about.
    [URL="http://www.heatershop.com/infrared_heater_mh42t.html"]
    Treat me like a newbie to this (as I am a newbie) and help me understand this.
    Share with Facebook
  2. #2
    Join Date
    Feb 2006
    Location
    Bristol, In
    Posts
    718
    Default Re: Propane Oven - I know it's been asked
    Just looked at your link to the heaters. I wouldn't put those inside any oven. I would think the propane tanks might explode. Do a search of this forum on PROPANE and it will give you several discussions on that subject. Most of the ones I've seen or read about, the heaters are on the outside.
    Share with Facebook
  3. #3
    Join Date
    Feb 2006
    Location
    Bristol, In
    Posts
    718
    According to the size you want, you would need about 192000 to heat to 400 deg. Here's a link for you to check out.
    http://www.heatershop.com/btu_calculator.htm
    Share with Facebook
  4. #4
    I wasn't going to put the tank inside. I was goind to black pipe it to a tank outside. These units are only about $130 bucks so if I needed 5 of them that is no problem. I was just wondering if they would do the job?
    Share with Facebook
  5. #5
    Join Date
    Jul 2006
    Posts
    738
    Quote Originally Posted by yyaarv View Post
    These are infrared heaters without a blower. I think most of the larger ovens you will find have an outside burner with a blower. I sent you a pm on a few other contacts.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. propane curing oven
    By trigger_happie in forum Oven Building Forum
    Last Post: 03-25-2008, 08:12 AM
  2. How do I connecta regular home gas oven to a propane tank? Please Help!!!
    By krisnet55 in forum Powder Coating Questions
    Last Post: 01-05-2008, 01:34 AM
  3. Since you asked....Lab Metal vs. PitStop ??
    By dwoodruff in forum Electroplating Questions
    Last Post: 09-18-2007, 06:48 PM
  4. oven build/ elec IR/ or propane IR?
    By Carcher7878 in forum Oven Building Forum
    Last Post: 04-06-2007, 04:29 PM
  5. advice on oven propane or electric
    By RCC in forum Powder Coating Questions
    Last Post: 11-26-2006, 09:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
