I used to use a generic home oven thermostat and found that the temp might drop from 450 to 435 before the burners would come back on. The PIDs are more than you need but I don't know of an inbetween alternative.
Gene |
Go here BTU Calculator
Mike MJM Powder Coating |
Your question " why is a PID needed?" is simple to answer, its not. There are numerous Temperature controllers available that are compatible with SSRs or Contactors. Most use "k" type (etc) themocouples and will control with a fairly tight control range. The part that this dosn't address is the expense. It appears that there is not a cost advantage by not purchasing a PID. It seems that temp. controllers, cost wise, are about the same money as a PID. Just buy a PID and use it as a temperature controller, keep it simple. Fred
| Fix Needed | donafams | Powder Coating Questions | 5 | 07-12-2007 11:54 AM |
| advise needed | gm_geek | Copy Chrome Kit Customers Only | 2 | 12-11-2006 04:46 PM |
| used 150 amp rectifier needed | JRH | Services Offered/Wanted | 0 | 12-27-2005 11:00 AM |
| plating help needed????? | don1965 | Electroplating Questions | 2 | 08-13-2005 08:20 PM |
| Electropolishing How-to needed!! | MattAnonymous | Electroplating Questions | 1 | 06-12-2004 11:17 PM |
