Old 04-15-2008, 04:30 PM
carlton43 is on a distinguished road
Question Oven question
When riveting or screwing inner panels together is it necessary to make some relief in holes for expansion as oven heats up. I cant help but think there would be buckling in the walls if tightened down. I am about to start building my oven.
Old 04-15-2008, 07:40 PM
ed_denu is on a distinguished road
Default Re: Oven question
I used galvanized sheet metal and haven't noticed this problem. If you screw/rivet every 6 inches or so I don't think there will be a problem.
Old 04-15-2008, 08:21 PM
JTW37's Avatar
The only real issue that I've noticed is if you use to thin of a gauge of steel, it will expand and contract with the temp variations. You will know this as it makes lots of noise. Ask me how I know this.
Old 04-16-2008, 07:37 AM
46Ford is on a distinguished road
Just a suggestion if you could have the shop that cuts and breaks your sheeting, have them put some "stiffening breaks" in basically the shape of a X from corner to corner. It will help to keep the sides from moving around quite as much. I definately agree with putting the rivets or screws fairly close together as well.
Old 04-17-2008, 01:14 PM
FigureLLC's Avatar
FigureLLC is on a distinguished road
we used 20ga (i think) galvanized steel on 25ga studs. 1/8" aluminum rivets spaced ~6" apart. i used an 1/8" drill bit, so no relief. this is a rather small oven (5x2x1ft), but it's been great. no warping, no noise during heating/cooling.
Len
Figure Engineering, LLC
Oven building question????? Mick40 Oven Building Forum 2 01-18-2007 10:43 PM
another oven question corybarta Powder Coating Questions 7 03-14-2005 11:07 PM
building a oven question Jay87T Oven Building Forum 3 03-01-2004 05:28 PM
oven question duke Oven Building Forum 34 12-11-2003 09:35 PM
Oven question for the Gurus jbento Oven Building Forum 1 05-16-2003 10:33 PM
Powered by vBulletin® Version 3.7.0
