Old 04-30-2008, 10:34 AM
4birdman is on a distinguished road
Default How many elements can I use?
I'm planning out my oven build, but I'm not sure how far I can go. I want to build a large one, but I realize that isn't gonna happen in my current shop.
My shop is currently almost maxed out as far as power goes, since it is attached to my house and I don't want to bother having a subpanel run since I will hopefully be moving to a bigger shop in the next few years.
So, the size of my oven will basically be dictated by how many elements I can throw in this sucker.
I currently have a 30 amp breaker on a standard household 220 outlet running my current household oven.
I'd like to build an oven that is 7'x3'x2' inside dimensions to fit the spot I have in the shop. I want to run two elements, one at the top and one at the bottom and be able to run the top one independent of the bottom one so I can partition it in half and only use one element if I only need half the oven size.
Would two elements work in an oven this size, or would it be better to have three? I plan to run a fan to get some heat to the center of the oven, or would this even be necessary with an oven this size and with a top and bottom elements?
Any advice?
Old 04-30-2008, 09:14 PM
ed_denu is on a distinguished road
Default Re: How many elements can I use?
You're limitation is going to be the 30 amp circuit you have available. You're probably looking at around 5800 watts maximum.
80% of maximum load is a good target so: 30 Amps * .8 = 24 amps max
24(amps) * 240(volts) = 5760 watts
How you divide the watts between 2 or 3 elements may depend on how you design the oven. I think you can get good heating results with your planned size of oven(42 sq ft).
IMO a recirculating or a convection fan always helps.
How big are my elements jnk-byr Oven Building Forum 4 04-21-2008 07:21 PM
elements sawman Oven Building Forum 6 08-30-2007 10:42 AM
Oven elements - Grill elements? KKamel Oven Building Forum 2 12-29-2006 08:48 PM
Where to buy elements? Deecoat Oven Building Forum 1 08-05-2006 08:00 PM
Elements dbug10 Oven Building Forum 8 02-22-2006 09:25 AM
Powered by vBulletin® Version 3.7.0
