1) The bottom would probably be a single-wall piece of sheet metal. The repeated heat/cool cycles would be bad for the concrete floor, no?
If there is proper circulation at the bottom 300 too 400 degrees is not going to cause the concrete floor to do anything but maybe sweat. If you preheat, the moisture will eventually evaporate. 2) How would the bottom door seal work? Look into high temperature door seals and or door sweeps. This is basically expensive. Another option is to use high temp mesh which is what I have done. It acts an insulation that is flexible and does a good job of wadding under the door. 3) I'd like the oven to be natural gas, so I couldn't mount the burner plate under the floor, so I'd have to have some kind of heat exchanger mounted to the rear, which would increase the oven's footprint, slow heating, and probably reduce the size burner I could use. Yes, building a fire box will probably be the most challenging. I am looking into modding a propane heater instead of an incinerator burner as the a/f is probably better regulated so there is less soot being placed into the air steam. This is my biggest problem when doing anything white or light. You can see the soot lay out in certain places. but you are using cleaner burning natural gas so your results will probably be better.
http://www.4wheelersanddirtbikes.com |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| corecoatings |
| home built oven | hammer396 | Oven Building Forum | 2 | 03-02-2008 07:56 PM |
| One Oven being built and contemplating | JTW37 | Oven Building Forum | 5 | 02-22-2007 07:11 AM |
| thermostat question,newly built oven is alive | gaskincrew | Oven Building Forum | 5 | 05-03-2006 08:09 PM |
| ? for everyone who has built an oven | mj134 | Powder Coating Questions | 4 | 07-17-2005 02:42 PM |
| need oven built in CA $$$$$ | showroomexpress | Powder Coating Questions | 0 | 03-14-2005 01:47 PM |
