You may have to run your #6 wire to a terminal strip outside of the oven wall and then size a wire to the element wattage to bridge the distance from the terminal strip to the element. You should be able to purchase hi-temp conectors to make up the element end of this jumper wire. Do you need spade lug or the slip fit type connectors ? Fred
I am needing quick disconnect 1/4 connectors. I was trying to find some for #6 high temp wire but I have ordered #12 high temp wire. I hope going to #12 wire will help with the search for these connectors. I have been all over Mcmaster Carr web site and they do not carry the high temp 1/4 quick disconnect connectors for # 12 wire. Does anyone know where I can get some. I cant find them at any local supply or electrical house.
| Element Connectors? | donafams | Oven Building Forum | 4 | 12-03-2007 05:06 PM |
| Wiring for a three element oven?Element Help | pappahenn | Oven Building Forum | 10 | 11-06-2007 08:32 PM |
| gold-plating small electrical connectors | gfergy | Electroplating Questions | 1 | 05-28-2007 02:25 AM |
| Titanium connectors | rbrandes | Anodizing Questions | 1 | 12-23-2006 12:08 AM |
| Gold PCB Edge connectors | ronscott | Electroplating Questions | 3 | 09-14-2002 11:59 AM |
