Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 05-31-2008, 05:57 AM
smokinbird89's Avatar
smokinbird89 is on a distinguished road
Send a message via Yahoo to smokinbird89
Default losing heat through the doors
I have taken an old Grieve oven and turned it into a potential powder coating oven. The inside dimensions are 68" wide x 66" tall x 33" deep. I have (3) 2800 watt elements. It took an hour and a twenty minutes to get to 373 degrees. I didnt wait any longer and shut it down. I added an extra 4 inches of insulation in the walls and 8 inches floor during the build. Using a heat gun I am losing a lot of heat through the doors. The doors are getting about 250 degrees while the rest of the oven outside only is warm to the touch. The only thing that I can think of doing is building a new single door to go on the oven or add another element to compensate for heat loss. Does anyone have any input on the matter.
losing heat through the doors-terrys-oven1-001.jpg   losing heat through the doors-terrys-oven1-011.jpg
Old 05-31-2008, 09:45 AM
Default Re: losing heat through the doors
I'd either rebuild the doors, insulate and seal the c r a p out of them...or make a new set.
It looks like it will make a nice oven when you're done.
Old 05-31-2008, 11:24 AM
ed_denu will become famous soon enoughed_denu will become famous soon enough
How are you measuring the temperature? Depending on where the thermostat is located and if you do not have a circulating fan then the temperature could vary greatly from one area to another. Try placing a couple of oven type thermostats at various places and observe the readings.
Old 06-01-2008, 06:40 PM
Would not having a circulation fan make that much temp difference? I was going to put one in down the road but if its going to make that much difference I will do that now. Does anyone have a link to a good fan for my application. I dont even have it vented and dont know why it has to be. Any and all info appreciated. I have also attached a few more pics.
losing heat through the doors-terrys-oven1-002.jpg   losing heat through the doors-terrys-oven1-010.jpg
Closed Thread
Lamps-Like heating a house with the doors & windows open mcaswell Powder Coating Questions 7 09-17-2008 05:52 PM
Fireplace Doors- Where Do I Start? PWright Metal Polishing Questions 2 07-20-2006 03:28 PM
to much heat? clockman Metal Polishing Questions 0 09-27-2004 10:38 PM
Heat Gun Jay87T Powder Coating Questions 1 06-23-2004 11:10 AM
