Is there an advantage to using the solid state relays (SSR) vs. the mechanical relays? I don't mind having a spare parts supply of high AMP SSR's on hand if there is an advantage. I have CNC machines in the shop and RF noise/line noise is a major factor. Mike |
There's a lot of noise and back-EMF induced on power lines with relays. You can also see sudden voltage drops and spikes as they switch on and off. A good line filter or APCs on your electronic gear would help. And as JT noted, SSRs require a hefty heat sink for longevity. Also, when SSRs are used to switch heater elements, you should down grade their rating by about 30%. (Use a 100A SSR for a 70A load, etc.) |
SSR's can fail in the closed position, that alone is enough reason for me not to use them. I have never seen a contactor fail closed, I'm sure it can happen but in the 13 years I have been an electrician I have yet to see one.
we use only magnetic contactors in our ovens . a few reasons . cheaper , no need for a heat sink, and like stated when they fail they fail open and cannot due damage to other things .
Go to the top of this forum and look in the Sticky or use this link.
Oven Building Material Links post #15
Who says you can't teach an ole dog new tricks? Last edited by JTW37; 08-26-2008 at 08:27 AM. |
| Tags |
| relay, relays, ssr |
| solid state relay | bjmill81 | Oven Building Forum | 1 | 03-01-2007 01:29 PM |
| Nickel Replate: acid etch still needed after mechanical stri | xiphmont | Electroplating Questions | 4 | 05-14-2003 12:57 AM |
| Mechanical plate stripping | xiphmont | Other Metal Finishing Questions | 1 | 09-27-2002 06:48 AM |
