  #11 (permalink)
Old 09-04-2008, 06:12 PM
SCOTTRODS is on a distinguished road
Default Re: Only have 110 volts, can I use my oven?
Originally Posted by FigureLLC View Post
we originally had the same problem. Our solution was to take a natural gas oven (we got it free off of craig's list) and change it over to propane. That process consisted of 1) flipping a piece in the oven regulator from "ng" to "lp" -$0, 2) screwing the orifice at the burner down tight -$0, and 3) changing the gas line so we could connect a 20lb lp tank, like for a grill ~$20. Worked great.
That is Genius !
  #12 (permalink)
Old 09-10-2008, 06:16 PM
leitnin is on a distinguished road
Hi guys,
First post here, I've been doing some reading.
Not trying to hijack the thread but I wanted to run with the propane idea.
I thought of the same thing when a friend got a new stove and I had to convert it back from propane.
I have plenty of power coming to the house, but I was more interested in using propane in an old oven for this.
My question is. I have seen very very many powdercoating suppliers etc. who say to never use a gas stove.
I would assume due to powder dust combustion.
Is this really that much of a concern? Can you reliably use a gas oven converted to propane? after all, Im not planning to spray powder in the chamber.
Thanks!!!!
  #13 (permalink)
Old 09-10-2008, 07:04 PM
Originally Posted by leitnin View Post
Hi guys,
Thanks!!!!
In recent threads on this forum and another I frequent,, it has been said that some powders actually put off a gas while curing, that can be explosive.
Gas ovens are the thing to use for comercial powder coating, but they are of the "no open flame" type. In other words, none of the typical household ovens should be used as they all have the "open flame" burners where the flame and the explosive gases can mingle.
If you have an oven that is confirmed "enclosed flame" then it will be perfectly OK and should be of no harm at all.
My oven SCHEMATIC...for new oven builders.. RNMHRD Oven Building Forum 39 05-09-2007 06:18 PM
Volts? nil8u Electroplating Questions 13 07-23-2006 08:44 AM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 11:40 PM
VOLTS AND AMPS livingspirit Electroplating Questions 5 05-12-2004 07:47 AM
Volts vs Amps BryanD Electroplating Questions 2 10-05-2003 03:56 PM
