Originally Posted by leimdog
I think I'd read your post a while back and tucked it away as a "must do" when I build my oven. I'm glad you provided feedback on that idea! Thanks a ton!
I'm just wondering what happens to the inside of the oven after time. Does it rust or anything? I've seen pics of the inside of ovens which used galvanized sheet metal and they're rusty. Is there any way to protect it?
--Jeff
The inside of my oven, as well as the outside are just plain bare steel. After using it for awhile, i noticed it was showing surface rust. That's when I got the idea of spraying it with Hi-temp engine paint. For the most part, it took care of and still is taking care of the major parts(panels) inside the oven. What I have been seeing is where I have the sheet metal panels fastened to the frame, has paint flaking off. Otherwise it is doing okay. Why it is flaking off is beyond me, but it is, as little. That's about all I can tell you about it.
