Looks to me you have a good starter oven. Good size. I made a 3x3x6 and now wish I would have went with a 4dx6wx7h. That will be my next one, maybe. Bumpers are a biitch in my 6 footer.
Keep the updates coming.
Who says you can't teach an ole dog new tricks? |
Finally done with the insulation. It felt like I had been tortured for 5 hours being covered in glass fibers. The one good thing about mineral wool is that it cuts really easy with a band saw using a 6tpi wood blade. Next comes the steel studs.
Looks like your making some progress. Yep, I found out the same thing. It takes a lot longer then you think it would. Can't remember exactly how long mine took, but it seemed like I was not ever going to get it done. Probably wouldn't get a UL stamp of approval, but I built it as safe as I could. No problems yet.
Why the insulation and hardy board? You going to cover the inside with sheet steel?
I used both to be sure it would hold in the heat and also was hoping the Hardy board and the air gap between it and the insulation would hold heat so when I opened the door I wouldn't loose it all. The pics show it laying down it is going to be 7 feet wide and 4 feet tall The door will be the entire front on a garage door track counterbalanced to easily lift straight up. So far the door weighs about a hundred pounds.
I am a big fan of Murphy "whatever can go wrong will" |
| Anyone With A Used Oven Or Can Build A Oven For Me, Ohio | REVS | Oven Building Forum | 2 | 01-04-2008 12:15 PM |
| My oven SCHEMATIC...for new oven builders.. | RNMHRD | Oven Building Forum | 39 | 05-09-2007 06:18 PM |
| Good oven shell for wanting to build your own oven | dannydone | Powder Coating Questions | 6 | 03-21-2006 11:40 PM |
| My PREP WORK : Pics INSIDE>>>Comments?? | cabrego | Powder Coating Questions | 13 | 03-25-2005 01:48 PM |
| Read this first. (helpful comments for all the new people) | non-stick | Powder Coating Questions | 1 | 12-30-2003 12:44 PM |
