+ Reply to Thread
Results 1 to 9 of 9
Thread: contactor to TET612 wiring?
  1. #1
    Join Date
    Jun 2007
    Location
    Southern N.J.
    Posts
    92
    Question contactor to TET612 wiring?
    Ok I've given up on installing a ssr,I bought a Square D definite purpose 50Amp contactor 2-pole open type 120v coil,how should I wire the controller and contactor?Thanks for your help.
  2. #2
    Join Date
    Oct 2004
    Location
    b'ham ala
    Posts
    64
    Default Re: contactor to TET612 wiring?
    i have the same unit and i would like to see other guys wiring.
  3. #3
    Join Date
    Jul 2006
    Posts
    815
    Something like this:
  4. #4
    Join Date
    Oct 2004
    Location
    b'ham ala
    Posts
    64
    cool, that makes alot more sense then the other ones. what brand/type contactor do u recommend with the te612?
  5. #5
    Join Date
    Jul 2006
    Posts
    815
    Quote Originally Posted by myillwillinc View Post
    Contactors are independent of the PID so most any of sufficient capacity will work. If you are going to use this schematic then you need a 2 pole contactor with 120 vac coils and of sufficient capacity to manage your elements.
    I personally use an SSR so I wouldn't recommend any specific one. Look at the first sticky on this forum for some suggestions.
  6. #6
    Join Date
    Aug 2009
    Location
    MN
    Posts
    1
    can the tet612 be used to bring up to temp, in this case boiling point, and then maintain temp for set period of time, say three hours and shut down automatically, can it be used for a timer while it maintains set point.
  7. #7
    Join Date
    May 2008
    Posts
    314
    Quote Originally Posted by tet612 View Post
    No, I am pretty positive the Tet612 does NOT have ramp/soak functions.
    Grumple
  8. #8
    Quote Originally Posted by Grumple View Post
    Which one(s) do?
  9. #9
    Join Date
    May 2008
    Posts
    314
    The easy answer there is "you get what you pay for". The cheap ones most always do not have RAMP/SOAK. I believe I noticed in another post that you bought a 1/32 DIN Model: SYL-1512A. At the Auber Instruments site here:
    PID Temperature Controllers : auberins.com, Temperature control solutions for home and industry you will see 2 of them listed with Ramp/Soak at $89.95 each. One uses an SSR output while the other uses a relay. There are many manufacturers of PID's and they can cost hundreds of dollars...
    Hope that helps,
    G
    Grumple
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Do I need a new Contactor?
    By TreyY in forum Oven Building Forum
    Last Post: 01-26-2008, 05:03 AM
  2. SSR or Contactor?
    By BottleFed70 in forum Oven Building Forum
    Last Post: 05-16-2007, 04:26 PM
  3. Contactor & Controller wiring
    By donafams in forum Oven Building Forum
    Last Post: 05-09-2007, 05:44 PM
  4. contactor wiring
    By chromeitout in forum Oven Building Forum
    Last Post: 02-18-2007, 03:41 PM
  5. What exactly is a Contactor for?
    By Scratch in forum Oven Building Forum
    Last Post: 01-25-2007, 01:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
