Ed- basically the heat exchanger is the Infrared red unit, thus there are no open flames present. This sounds more effiecent then using a standard convection heat exchanger. BTU for BTU there is less loss and more direct energy applying into the oven then the loss from asorbtion in a conventional metal---> Air heat exchanger. If im wrong let me know, seems like a lot of these huge commercial Pc booths i see are Propane infrared units.
LinkBack URL
About LinkBacks
