Hey guys im new to this forum. Just picked up all my 1/8" steel and angle to make a solid 4x4x4 box. Im going to use hightemp insulation from lowes.
My dilemma is...
Should i used a forced air propane heater/ torpedo
HVACR > Heating Equipment > Portable Gas Heaters > Heater, Torpedo,Lp : Grainger Industrial Supply 100,000 btu
HVACR > Heating Equipment > Portable Gas Heaters > Heater, Torpedo,Lp : Grainger Industrial Supply 150,000 btu
OR
Propane powered Infrared Heater.
HVACR > Heating Equipment > Unvented High Intensity Infrared Heaters > Heater,Infrared : Grainger Industrial Supply 30,000 btu
HVACR > Heating Equipment > Unvented High Intensity Infrared Heaters > Heater,Infrared : Grainger Industrial Supply 60,000 btu
HVACR > Heating Equipment > Unvented High Intensity Infrared Heaters > Heater,Infrared : Grainger Industrial Supply 90,000 btu
Im not spraying powder in my booth only baking the objects in it. For spraying im constructing a frame from PVC tube and using thick clear plastic walls with a hepa filter and fan hooked up. Then transfering the part into the oven so i dont have all kinds of particles in the air.
I used the btu calculator ( BTU Calculator provided by the heater shop .com )
My settings were:
Good insulation/Tight leakage
Temp increase: 400
square footage to heat: 4 Feet by 4 Feet
Ceiling Height: 4 Feet
BTU 16,000
Average insulation with same dimensions and heat:
BTU 32,000
Poor insulation and loose leakage:
BTU 64,000
Its going to be insulated with hightemp 1500+ F insualtion from lowes/homedepot.
Option one:
The problem i see with the torpedo propane blower is it blows it at 400CFM. well in an enclosed spaced with no vents i dont see how that will work to great. Even if i did vent it most of the hot air would escape. i would most likely have to use more then one unit to superheat the box initially then use a single unit to keep the heat up. This sounds like a pain in the A$$ and lots of propane wasted. I personally dont think ill go this route.
Option two:
Infrared Heater. I like this idea a lot! i dont have a massive 400cfm blowing around and i dont have to worry about venting it. It seems like this would be the obvious choice. Since heat rises i would mount it beneath the steel box upside down, letting the heat rise up. Sounds like more of a normal oven. Im just wondering how i can evenly distribute the heat. Hopefully it doesnt have a damn thermostat on it so i can leave it cranked up to reach 400 degrees.
Dayton: I could save a few hundred bucks and hit up the cheaper brands at lowes and homedepot but im going to be building and using this for some time so i want the quality right now, even if i have to pay a bit more.
Please help me out, like i said electric is out of the question this puppy needs to be portable
my email is sales@avery-industries.com
My cell number is 253-617-5753
Please contact me via email or repost on the forum, i will be taking hundreds of pictures of the full build and posting them on this site (if allowed). I think it will help others as well to jump on the wagon to make there own ovens! thanks guys hope to hear from you soon!
Jeremiah
LinkBack URL
About LinkBacks
