I ordered my insulation, mineral wool, from a locally owned building supply store here in Western WA. Its used in the building industry around fireplace and stove chimneys. Some of the oven builders buy it from the likes of McMasters. Good luck! Fred
There may be some that disagree with me on this but I build my oven and used R-30 pink insulation and it works great, gets to 450 degrees in 4 to 5 mins and holds the temp great. I called owens corning before I made the decision to use it and the R-30 pink insulation is good up to 1200 degrees. Just make sure you get the unfaced, can't use the faced the paper wont take the heat, but as long as you go with the unfaced it works great. Hope that helps you out.
Kevin Smitley |
most of your house hold ovens use this type of insulation , it does work
www.tedsfabrication.com big oven for sale cheap on ebay ... no reserve http://cgi.ebay.com/ws/eBayISAPI.dll...m=120441937766 |
Thanks for the info Ken, Yea the Guy at Owens Corning said it would be good up to 1200 degrees, but who knows, LOL.
I went with the R-30 because it was the cheapest that the Home Depot here had, $14.37 a roll, I used 2 rolls on my oven, I didn't figure $30.00 was to bad. The R-30 that I used was 9" thick, it wasn't to bad getting in there it seem to smush down pretty good, but I didn't know about the air gap thing, but like I said it seems to work pretty good. Kevin Smitley |
| oven insulation | djlaserob | Oven Building Forum | 9 | 12-02-2006 08:50 PM |
| Insulation mistake ??? | palmbeach | Oven Building Forum | 3 | 07-22-2006 01:48 PM |
| Insulation | FoxRider1488 | Oven Building Forum | 1 | 06-28-2006 09:55 PM |
| insulation help | gaskincrew | Oven Building Forum | 9 | 05-19-2006 12:34 AM |
| Where to get insulation? | remotestartdepot | Oven Building Forum | 9 | 02-13-2006 12:46 PM |
