Which wiring diagram could I use on here for 3 2000W elements? If thats OK? Right now my walls are constructed and up with 4" insulation. |
Welcome to the forum. The (3) 2000 watt elements will only consume 25 amps so your service panel should easily support the circuit.
But imo 6000 watts is inadequate for this size oven. With 96 cu ft you are only looking at 62 watts per cu ft. I think anything below 100 will be an extremely slow heat up cycle. The elements need to be wired in parallel, not series, so any of the wiring diagrams would work. Before buying any components finalize your control box layout and then match all components(pid, ssr/contactor, elements, etc.) Do a search on the schematics available here, or send me your email and I can forward several schematics I have. Ed |
i would go with no less than 10k watts . if you want to make it easier to wire up your could just go with 3 3200 elements and that would get you close to 10k , and you would not have that much more wire involved .but since you already have the elements . maybe just get 1 3200 element .
www.tedsfabrication.com big oven for sale cheap on ebay ... no reserve http://cgi.ebay.com/ws/eBayISAPI.dll...m=120441937766 |
As Ted pointed out you do need to get to 10K watts minimum. |
This is what i ordered and a friend has used these and they work great
Replacement for GE Broil Element WB44K10002 NEW! - eBay (item 400004473670 end time Jan-24-09 02:43:58 PST) scott |
couple of questions. Is 11100 enough on elements?
What size wire do I need coming from my elements? Were is the best place to put my vent?(1" with elbow) My elements are, against the wall facing up. I have one on the back wall and 1 on each side. Were is the best place to put a fan? Im getting this one for now. Motors > HVAC Motors > 3.3 Inch Diameter Motors > Motor,1/100 HP,3.3 In : Grainger Industrial Supply |
| 2000W Elements? | donafams | Oven Building Forum | 3 | 05-04-2007 06:10 AM |
| CFM needed for 4x4x6 oven? | edwardpic | Oven Building Forum | 15 | 07-18-2006 03:55 PM |
