Results 1 to 3 of 3
Thread: Insulation question
  1. #1
    jeeplogic is offline Amateur Metal Finisher
    Join Date
    Mar 2009
    Location
    W. Michigan
    Posts
    79
    Default Insulation question
    A long drawn out question but it's bugging the **** out of me.
    I thought that I would put 1-2 inch of mineral wool and then fiberglass behind it but what is the difference fiber glass is made from spinning grains of glass beads at just over 2000 degrees f. mineral wool is made in the same process using Iron slag and basalt rock at approx 2800 degrees f. both use formaldehyde binders in the glue holding the weaves together, both have a melting temp well over 1500 degrees f. which is probably 3 times temp I would ever bake anything.
    So, Here is the question.
    Why the he!! would I pay 2-3 times as much for mineral wool that is almost impossible to find locally?
    I know a lot of the guys here use fiber glass. If you do how long have you had your ovens in service and how are they holding up?
    Thanks
    Greg
    check out my oven building section
    www.priority1signs.com
  2. #2
    ed_denu is offline Metal Finishing Guru
    Join Date
    Jul 2006
    Posts
    1,148
    Default Re: Insulation question
    I used un-faced fiberglass in my oven a year and a half ago. I had a panel off awhile back and it appears to be the same as when I installed it.
    I don't have the numbers available but I suspect the mineral wool has a higher insulation factor than the fiberglass. If you intend to use your oven multiple hours on a daily basis then I would go with the mineral wool. If you are just using it a few hours or so a week then the fiberglass would be fine imo.
  3. #3
    yzviper is offline Newbie
    Join Date
    Nov 2006
    Posts
    30
    I got my mineral wool from McMaster. Fortunately I have a branch 40 minutes away. But their shipping charges are not bad for other things I've had them ship to me.
Thread Information
Users Browsing this Thread
  1. Insulation Question
    By donafams in forum Oven Building Forum
    Last Post: 04-25-2007, 07:21 AM
  2. Insulation
    By FoxRider1488 in forum Oven Building Forum
    Last Post: 06-28-2006, 09:55 PM
  3. another simple insulation question ,mineral wool
    By gaskincrew in forum Oven Building Forum
    Last Post: 05-29-2006, 05:31 PM
  4. insulation help
    Last Post: 05-19-2006, 12:34 AM
  5. Totally off topic question about Insulation
    By tomg552001 in forum Other Metal Finishing Questions
    Last Post: 12-26-2003, 02:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
