Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: making oven
  1. #1
    Join Date
    Apr 2009
    Posts
    7
    Default making oven
    hey im david im 18 and i drift 2 1984 datsun/nissan 200sx's
    im trying to get towards suspensiona nd rims and have spawned interest in powder coat
    i have a welder etc. got the eltric oven today for free.
    planning to make it bigger
    whats a good temp i need for powder coating?
    any tips, or info? thanks!
  2. #2
    Join Date
    Apr 2009
    Posts
    7
    Default Re: making oven
    helloooooooooooooooooooooooooooo
  3. #3
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by whatrwedoingnow View Post
    24 hours and you've not gotten a response? Odd. If I tell you something that is completely eroneous, then someone will pipe in and correct me I'll bet....
    funny thing about this one, is your biggest question is a Coating Question, not really an oven question.
    If you go to almost any website that sells powder, they have the powder listed and the curing paramaters right there with 'em. Most powders cure between 350-400 degrees.... Some a little higher, some a little lower.... Some really fast, some take a while longer. To sum up though, each powder has it's own curing parameters....
    If you build your oven to go above 500, to maybe 550, outgassing parts will be much more effective, as you generally want to cook cast parts at 50 to 100 degrees above cure temp, for at least a double cure cycle time,.... as part of the preperation for coating. Billet and sheet metals do not need outgassing unless they are assemblies that cannot be un-assembled,... ie, welded or riveted.... This outgassing will cook off grease or bring it to the surface of the cast part or out of cracks and seams of assemblies.
    A few considerations anyway....
    Oh .... these are my opinions and I'm certainly not claiming to be the "be-all end-all" in this department.
    EMAIL scott@scottrodspc.com
  4. #4
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Sounds good to me Scott.
  5. #5
    Grumple is offline Experienced Metal Finisher
    Join Date
    May 2008
    Posts
    314
    Sounds good to me too Scott.
    Grumple
  6. #6
    Join Date
    Apr 2009
    Posts
    7
    sounds great scott. so outgassing is basically just cooking whatever i powdercoat before i powder coat, doing it around 40 degress higher then w/e the temp is supposed to be
    is it bad to powder coat a hot piece of metal? or should it be cool? and, do i need to make smooth object porus with sand paper, for powder coating
    advised, i bought a welder 2 days ago, my welds blow
    I AM, buying 1/2 inch sheet metal, or 1/4 do insulate the inside, leaving a inch space less then what you see
    am i going in the right direction? critisize, or however you spell it hehe
  7. #7
    Join Date
    Apr 2009
    Posts
    7
    i will be doing supports and possibly a insulation layer
    the right side will have a viewing window made from glass
    welding sheet metal sucks! so far its just tacked together, ill be sealing it up soon
    this morning i added the start of supports. my welds suck. they hold though im trying to get better, butt this sheet metal isnt the thickest
    most deffinetly entertaining a insulation layer to retain some sort of heat
  8. #8
    Join Date
    Apr 2009
    Posts
    7
    ugh i need sleep or something, im exausted no sleep sucks
    fell asleep around noon. and woke up around 7, and did some more work
  9. #9
    Join Date
    Apr 2009
    Posts
    7
    will be using the other door on the bottom if it fits, or ill extend the one on there
    and the pole across is where ill be hanging ****
    the welding is slowly getting easier
    and the swivels. hold the door,so i say im doing a decent job
    the parts with the poles, ill be welding thicker sheet metal, so it will retain heat, an leave 1 inch space between the sheetmtal, and the inside thicker sheet metal
    http://www.eastwoodco.com/shopping/p...ProductID=5572
    buying that kit, saturday. is that alright?
  10. #10
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Eastwood Co. - Hotcoat Powder Coating Deluxe Kit
    Man, I'm amazed at the many ways people do this stuff! Not how I'd do it, but it may just work fine. The biggest problem I'm seeing in your build, is the amount of space you are allowing for insulation. Rule of thumb is, 1" if insulation for every 100 degrees of temp rise you expect. So If you are looking to raise the temp to 500-550, you'll need 4.5 - 5 inches of insulation. At the 550 range you can still get away with 4 inches of ins.... but there will be a price to pay in heat loss, and energy bills.
    The gun set-up is a good start for a person to learn and coat a lot of schmancy stuff with.... There are many others to check out too, in the same range of price.
Thread Information
Users Browsing this Thread
  1. Making oven
    By dfj73 in forum Powder Coating Questions
    Last Post: 04-07-2009, 09:28 PM
  2. Making AL black?
    By TrekJeff in forum Other Metal Finishing Questions
    Last Post: 02-05-2009, 09:20 AM
  3. Could use a little help making decisions
    By osobob in forum Powder Coating Questions
    Last Post: 11-26-2007, 03:33 AM
  4. Making an oven and ive got a few questions
    By Tofurkey in forum Oven Building Forum
    Last Post: 07-18-2006, 10:30 PM
  5. Making $
    By FMXhellraiser in forum Powder Coating Questions
    Last Post: 07-04-2004, 05:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
