Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
  #31 (permalink)
Old 10-09-2009, 10:19 PM
StlS_Ron is on a distinguished road
Default Re: Lurked for long enough. couple of ?s on new build
This is what was supplied via email with the pid. I followed that eaxctly. With the exception of two elements
Let me know what ya think
also can you point me in the direction of a 5 or 6 foot thermocouple. I extended mine and I think that ithas thrown off its usage
  #32 (permalink)
Old 10-09-2009, 10:47 PM
Grumple is on a distinguished road
Here is a link for the type K thermocouple:
Temp Sensors, Thermocouple : auberins.com, Temperature control solutions for home and industry
If you extend it with the correct thermocouple "lead wire" it would work fine. Best if welded as opposed to solder-less connector/wire nuts etc...
Grumple
Grumple
  #33 (permalink)
Old 10-09-2009, 11:10 PM
ed_denu will become famous soon enoughed_denu will become famous soon enough
The schematic looks to be drawn for 120 volts. It would be basically the same if you supplied 240 however.
I would do the steps I recommended previously when you get a new ssr. If the pid energizes the ssr/elements when the sv is less than the pv, then something is wrong.
  #34 (permalink)
Old 10-10-2009, 03:07 AM
Grumple
great link, I just ordered enough to build another oven. Thanks
I will def check the pid
I just assumed that both legs at the top of the diagram were 110 each. I ran a the ground to the control box and oven.
Ed and grumble thanks guys.
  #35 (permalink)
Old 10-10-2009, 11:51 AM
Caswell Platinum Member
mtg125 is on a distinguished road
Ron thanks for the offer on the blasting gun, but it needs to many cfm's for my compressor. If you want to run down and look at how mine is wired up let me know.
  #36 (permalink)
Old 10-22-2009, 08:01 PM
See the above comment.
The pid controls the ssr on/off cycle. If you get another ssr and the same result occurs, shut it down immediately and trouble shoot the problem.
I would first test the pid without the ssr connected. Set the sv to be less than the pv and do a voltage check(DC) on the two pid output terminals that control the ssr. There shouldn't be any voltage on the mm. Then move the sv to be greater than the pv and check the voltage again. You should see a DC voltage of around 8 volts. If this is correct then the pid is working ok.
Finally got the new ssr. Stabbed it in there tonight with some thermo paste. Works like a charm.
do you know how long the Autotune function takes?
  #37 (permalink)
Old 10-22-2009, 09:31 PM
Autotune can run up to 30 minutes or so. It will ramp up to your set temperature, then cool down a little and heat up again to the set temp. It will go over the target somewhat so don't be alarmed if it does.
  #38 (permalink)
Old 10-23-2009, 01:45 AM
right at about 30 mins actually. worked great.
Ed have you ever used the alligator clip on thermo couple? I think i may buy one if anyone has had any luck with it.
  #39 (permalink)
Old 10-23-2009, 09:51 AM
Yes, I built a version of my own. I don't connect it to the pid, it's a separate unit. It's detailed in this link:
Contactor/ PID question
A couple more pics! Thanks! k10seibel Oven Building Forum 2 06-21-2007 11:07 PM
Couple questions RobsPCing Oven Building Forum 15 02-23-2007 09:36 AM
Couple questions RobsPCing Oven Building Forum 0 02-16-2007 11:59 PM
A Couple Questions HDGP Powder Coating Questions 2 05-18-2006 07:16 PM
Couple of ?'s tavo1765 Powder Coating Questions 2 02-05-2005 05:27 PM
