I've been following this thread with some interest. Have you figured out how to light the heater automatically yet? I was thinking a thermo-coupler and a peizo would be part of the puzzle but I'm not sure how that would all tie together.
According to the AGA(American Galvanizers Association) galvanized steel can begin to have problems starting at temperatures of 390 degrees. Here is an excerpt from their web site:
"Very high temperature environments can have an affect on galvanized steel. These effects depend on the time exposed and the severity of the environment. When considering long-term exposure, the recommended maximum service temperature is approximately 390 F (200 C). Problems that could occur from long-term exposure to temperatures above this level include peeling. Peeling is caused by closely spaced voids that expand and form a gap, it causes the outer free zinc layer to split-off from the underlying zinc-iron alloy layers. However, the remaining zinc-iron alloy layers will still provide a high level of corrosion protection for many years. At temperatures ranging between 390 F (200 C) and 480 F (250 C), the zinc-iron alloy layers will continue to protect the steel from corrosion. High temperatures above 480 F (250 C) will accelerate peeling and continued exposure can result in the zinc-iron alloy layers cracking and separating from the steel. Temperature applications of hot-dip galvanized steel above 480 F (250 C) are not recommended. When considering short-term usage, that is, periods of less than two hours at a time or onetime temperature excursions for less than twenty-four hours, the recommended maximum service temperature for galvanized steel is approximately 660 F (350 C)". |
Read the thread again. It is automatically fired by the pid with a 110V solenoid valve.
So what your saying is that everybody's oven is going to start to fail? Most people's oven are sheeted with galvanized and I have never heard of issues with it failing or giving of noxious gasses. |
As for fumes, my understanding is that zinc melts around 900 degrees and vaporizes around 1650 degrees. These temperatures are much higher than most PC ovens would encounter. Zinc fumes are more of a concern when welding galvanized steel and proper protection, including the use of an appropriate welding mask should always be used. Last edited by ed_denu; 07-29-2009 at 09:38 PM. |
I have not taken it over 400 yet. Why would you want to go to 700?
See photos of my work at the following link http://s244.photobucket.com/albums/gg6/terrellster/ |
I think for Ceramics. They cure at around 600-650 I think....
| Anyone built a natural gas fired oven????? | asalony | Oven Building Forum | 0 | 05-21-2008 06:38 PM |
| oven build/ elec IR/ or propane IR? | Carcher7878 | Oven Building Forum | 8 | 04-06-2007 05:29 PM |
| Gas fired oven in central PA or Northern MD | datadawg | Oven Building Forum | 2 | 05-10-2006 09:39 PM |
| Gas fired oven | dfarning | Oven Building Forum | 5 | 04-12-2006 10:40 PM |
| Gas fired pizza oven for curing? | BlindUmpire | Oven Building Forum | 4 | 02-28-2004 12:21 AM |
