the other question if the air come out of the heater if strong or not. Thank you very much Big Toy for your Time. |
So I finally got around to testing the upper temps for the oven. After I got done with a few parts I cranked the pid up to 600F.
400-500...10min 500-500...10min 550-600...10min So, it went from 75 to 600F in about 45 minutes. out side oven temp on the wall was about 95F. |
It has to work pretty hard to keep 600F. Maybe 80% duty cycle. At 400F it only about 25% duty cycle.
Bigtoy:
Nice job on the oven!! I have one of those PID's on my electric oven (5'x5'x7'), works great as far as accuracy, probably overkill but I can also use the same oven with other programed temp curves to mold plexiglass. Question..I am building a big propane oven (8'x8'x24'), the pid on the electric oven turns the power on and off very rapidly when near or at set point, like on 1 sec. off 1 sec. on 1 sec...... , SSR's can handle that. Does yours turn the gas on and off often? If so have you worried about lifespan of the valve? Morgan |
PID's normally have a 'cycle rate' parameter that allows you to control the frequency of the on/off cycling. My pid goes to 199 seconds.
Only issue would be maintaining the set temperature if the cycle rate were set to high. |
It does cycle pretty fast. On for a few seconds off for a few seconds. When the oven heat soaks for a wile it does no cycle as much. I am not too worried about wearing out the valve. It is cheap.
Do you have a brand and part number or more specs on the valve? You say its cheap but when I google "gas valve" I get stuff $40-$400 on up. Any other words of wisdom for someone trying to wire one up? Thanks.
| Anyone built a natural gas fired oven????? | asalony | Oven Building Forum | 0 | 05-21-2008 06:38 PM |
| oven build/ elec IR/ or propane IR? | Carcher7878 | Oven Building Forum | 8 | 04-06-2007 05:29 PM |
| Gas fired oven in central PA or Northern MD | datadawg | Oven Building Forum | 2 | 05-10-2006 09:39 PM |
| Gas fired oven | dfarning | Oven Building Forum | 5 | 04-12-2006 10:40 PM |
| Gas fired pizza oven for curing? | BlindUmpire | Oven Building Forum | 4 | 02-28-2004 12:21 AM |
