Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Old 05-20-2009, 12:36 AM
bigtoy302 is on a distinguished road
Default My propane fired oven build
I am in the process of building a 4x4x8 oven. I decided to be different and use propane for heat instead of electric. I will be using a 55,000 btu MR.Heater forced air heater. I will be controlling the heater with a Auber pid. I am using Roxul AFB for the insulation. Framing is 25ga steel studs and I am using 18ga galvaized for the sheets. I did not want to go that heavy but I got 10 sheets for $185.
Today I got the base all done. I put wheels on the bottom so I move it around easy.
Old 05-20-2009, 01:06 AM
jeeplogic is an unknown quantity at this point
Default Re: My propane fired oven build
looks nice so far
Greg
check out my oven building section
www.priority1signs.com
Old 05-20-2009, 08:27 AM
FigureLLC's Avatar
Caswell Platinum Member
yup, and sounds like you're on the right track.
Len
Figure Finishing
www.FigureEngineering.com
866-900-4949
Old 05-22-2009, 12:25 AM
I got the rest of the oven framed in today. I still need to frame the door.
Old 05-24-2009, 01:53 AM
I got the door all done and insulated then sheeted the oven. I still need to make the mini door and wire it up.
Light and Thermocouple wires.
Old 05-24-2009, 01:54 AM
Old 05-24-2009, 01:55 AM
Exhaust side.
  #8 (permalink)
Old 05-26-2009, 04:12 PM
leimdog
Looks great! I plan to go all propane too. Didn't know how I was going to control the temperature yet. I thought of going with cast iron propane burners from a grill or using my torpedo heater as you're doing.
So this Auber pid you've referenced will be able to control the temp? How does that regulate it? (I'm trying to learn more)
  #9 (permalink)
Old 05-26-2009, 11:37 PM
The pid will control it just like if it where electric. The pid will tell the heater to turn on at a certain temp and off at a certain temp. I Installed a 110v gas solenoid to control the heater. See next post.
  #10 (permalink)
Old 05-26-2009, 11:38 PM
I got my valve today and got it installed. I took out the push button valve and put the solenoid in it's place. I spliced the wires into the 110v coming into the heater. I also got the control box all mounted and the pid and switches hooked up. The right switch is for the light and the left one is for the heater.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Anyone built a natural gas fired oven????? asalony Oven Building Forum 0 05-21-2008 06:38 PM
oven build/ elec IR/ or propane IR? Carcher7878 Oven Building Forum 8 04-06-2007 05:29 PM
Gas fired oven in central PA or Northern MD datadawg Oven Building Forum 2 05-10-2006 09:39 PM
Gas fired oven dfarning Oven Building Forum 5 04-12-2006 10:40 PM
Gas fired pizza oven for curing? BlindUmpire Oven Building Forum 4 02-28-2004 12:21 AM
