Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
View All Announcements (3) Announcements in Forum : Powder Coating Questions
07-22-2009 until 12-22-2009
lcaswell's Avatar
lcaswell lcaswell is offline
Caswell Inc President
Turn Any Powder Coating Into A Liquid Paint
Now Available from Caswell - Tech-Line Coatings Liquid Powder.
http://www.caswellplating.com/aids/t...ml#liquipowder
Mix with any powder coating to turn that powder into a liquid paint that is sprayable with any spray gun.
This product makes it possible to coat wood and plastic with powder coatings.
Liquid-Powder can be used to touch-up areas on a part that has been powder coated (by electrostatic or other method), but has an area that was missed or was damaged in handling:
Repair of a damaged part can be accomplished by using a small touchup brush, toothpick, paperclip, etc… dipped into the Liquid-Powder and lightly applied to the damaged area, allow to dry then bake.
This process can be used to fill small holes in parts as well. If the part has been fully cured a light sanding of the damaged area is recommended to give the repair a surface to hang on to.
Lance Caswell
Have A Web Site?
Forum Jump
