Go Back   Caswell Inc. Metal Finishing Forums > Electroplating Questions > Plating Pot Metal
Connect with Facebook
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
Closed Thread
Old 02-06-2004, 08:11 PM
customandsound
Guest
Posts: n/a
Default chrome stripping ?
what can i use to remove chrome off of a harley primary cover?
Old 04-28-2004, 11:08 PM
use 1 part hydrochloric(muratic) acid to 2 parts distilled water. ALWAYS ADD ACID TO WATER, NEVER WATER TO ACID. Immerese for 5 min to 1 hour until you see a milky white residue on the part. This residue will wash off. You can speed it up by using a lead cathode and a dc power supply if you have access to that. Muratic can be found at home depot or lowes commonly called concrete cleaner. Acid can be nuetralized with baking soda if you spill any.
Old 04-28-2004, 11:23 PM
One other thing, I am assuming you know the difference between the chrome layer and the nickle layer. To remove the nickle you use sulfuric acid and water. BTW nice polishing job on that aluminum primary in the pics section.
Old 04-29-2004, 01:08 AM
customandsound
Guest
Posts: n/a
thank's fsxtcguy.... i got a set of byod's out of that deal ..it was for my uncle . switch blade style wheels 17X8 .. i got another one to do that is powder coated .. so let the fun start again ......
Old 06-12-2007, 02:36 PM
upncoming's Avatar
upncoming is an unknown quantity at this point
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
Default Re: chrome stripping ?
were can you get the sulfuric acid?
D.I.L.U.S.I.
Drive It Like You Stole It
Old 06-12-2007, 08:47 PM
tbreaden is on a distinguished road
The cheapest is a battery distributor. I pay $15.00 for 5 gallons.
Closed Thread
Stripping chrome plating from aluminum bbqboyee Anodizing Questions 4 04-22-2006 02:22 AM
Copy Chrome Start-up Elitefisherman Electroplating Questions 10 04-18-2004 05:24 AM
Chrome (re)plating question - howto olaf_sc Electroplating Questions 1 07-29-2003 03:00 PM
Stripping chrome from plastic txturbo Electroplating Questions 1 06-13-2003 03:42 PM
Hard chrome vs triple chrome butters Electroplating Questions 1 02-20-2003 12:35 AM
