| Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them. |
If it's potmetal, you don't want to strip in chemicals potmetal reacts badly with acids. Because of the "bubbles" there will be pits in the potmetal that you will have to fill with solder (if they are deep and black, you may have to drill the black out). Clean, sandblast, rinse and strike nickle immediatly. Then acid copper and fill the pits with solder sand buff and plate as normal. Potmetal is a nightmare, especially if it's really old. As far as alum, I don't know of any stripping method that doesn't attack the base metal other than blasting. I may be wrong on this one, if there is a way I would like to know it too. I'm tired of sanding and buffing the blast profile off. Good luck.
Darrin |
ok this is what works for me . put the part in the chrome stripper for about 10 to 15 min with about 50 amps on it. this will take off the chrome and some nickel. the longer you leave it the more nickel it will remove check it often. then blasting is easy saves tons of time. its just my way of doing it so try it if you want. good luck( better to use a high ph than a low on pot metal)
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
Sorry pickleboy,
Since this is the plating pot metal forum, I assumed you were plating it. Put a drop of sulfuric(battery) acid or muratic(hyrochloric) acid on the bare metal, if it bubbles violently, it's potmetal. Are you going to remove all the nickle plate? I don't think potmetal will hold a shine without plating on it, it will turn black, maybe it could be zoop sealed. Darrin |
| PLATING POT METAL............... | 48Buick | Plating Pot Metal | 31 | 08-29-2007 11:40 AM |
| Plating over cold metal casting | jh2ohouse | Electroplating Questions | 2 | 12-16-2006 08:28 PM |
| Plating pot metal for corrosion protection before painting | rspencer | Plating Pot Metal | 2 | 08-02-2004 11:39 PM |
| Refinishing Metal Golf Club Heads | BillSchultz | Other Metal Finishing Questions | 0 | 08-17-2003 10:40 AM |
| Pot Metal Plating questions | Dave | Electroplating Questions | 1 | 04-03-2002 05:37 PM |
