Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Plating Pot Metal
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
Old 03-10-2006, 09:53 PM
awdmh is on a distinguished road
Default Sean, or others; carb plating question
I have a home brew zinc-plating setup. My question for you more experienced fellows is how do you effectively plate the nooks and crannies of carbs and other irregular surfaces. I deal mainly with the old Holley 94s. Many thanks, and please check out my other questions about the chromate as to temperature of the solution, ratio of DI water to powder, and type of container for solution; plastic metal, etc. It is the yellow chromate.
Old 03-11-2006, 12:05 PM
Zinc Plating Guru
Default Re: Sean, or others; carb plating question
You've already tried and can't get good plate in nooks & crannies? What kind of home-brew electrolyte?
Chloride zinc electrolyte (Caswells variety) has excellent throwing power, and should have no problem getting into tight spots. I haven't plated a carb body yet (maybe this weekend), but I've done quite a few other odd shaped items with recesses, and they all plated fine.
Sean
Seans Zinc Plating page
Old 03-12-2006, 12:59 PM
It is a vinegar base soltuion, very low-tech. That's no doubt the problem. I have a recipe and basic ingredients for a chloride base solution I will try. Thanks for the help.
The chromate container says to use .5-2 oz per gallon. I like the looks of your projects, what ratio are you using?
Old 03-12-2006, 08:55 PM
Zinc Plating Guru
I've never heard that vinegar could even be used for the electrolyte, and it would seem contradictory.
Zinc is very reactive, and dissolves easily in acids. Vinegar is an acid, and can be used to strip or activate zinc surfaces. So it sounds like your vinegar based electrolyte might be working against itself, stripping the zinc plate almost as fast as it puts it down?
Are you using zinc anodes, or have you dissolved the zinc in the vinegar first?
Caswells electrolyte has zinc dissolved directly in the electrolyte, so anywhere the fluid finds its way into, will plate. Some zinc is transferred directly from the anodes to the parts, but quite a bit of it is simply to replenish the zinc plated out of the electrolyte.
Sean
Old 03-12-2006, 11:28 PM
Both, I dissolve zinc in the vinegar, then add epsom salt, table sugar, and then use an zinc anode.
Question on gold plating oldtoys1961 Electroplating Questions 4 05-07-2008 10:41 PM
Weber DCOE carb plating suggestion.... D Plating Pot Metal 3 03-09-2006 09:15 PM
Improving Plating Performance jimcarry Electroplating Questions 0 09-28-2005 08:50 AM
Copy cad/zinc plating question. 69t120 Electroplating Questions 1 07-07-2004 10:14 PM
A couple carb plating questions KenL Plating Pot Metal 0 01-23-2004 08:34 PM
