Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Plating Pot Metal
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
Old 10-06-2006, 07:45 AM
Gunjji is on a distinguished road
Default Flash copper connection problem
Hey, I just got my Flash Copper kit, got it all set up and when I hooked up the parts and turned on my cc/cv I coulnt get any amps. I thought it was the connection so I re-wired the parts and still no amps. The volts were fine, I could adjust no problem but my amps stayed at 0.0 no matter what I tried.
When I put the part in copy chrome and tried it, I had amps... Wired the same, copper wire with copper cross bar.
My part is a water pump cover on my dirtbike, zinc die cast I think.
The hook up is the same as copy chrome right, Positive to plates and Neg to part?
Thanks for any help....
Bryan
Old 10-06-2006, 02:02 PM
Default Re: Flash copper connection problem
Well.... Thanks to Tech Support, I found my problem! The part is die cast aluminum and I had to Zincate first.
All is good!
Flash Copper Problem gwjohnso Plating Pot Metal 12 02-27-2007 11:41 PM
Keep getting blisters in flash copper plating...HELP gtabadboy Electroplating Questions 7 11-17-2005 08:19 PM
Buffing Copper flash hefrod Electroplating Questions 3 09-21-2005 12:27 PM
Newbie ? on copychome and flash copper? KevinW Plating Pot Metal 3 11-08-2002 12:49 PM
