| Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them. |
I am working on a rear window frame off a 57 Chevy. It is cast pot metal. I have cleaned out pits and have flashed coppered it. It looks great. I am using plumloy to fill in pits. It does not flow smooth, I have used a propane and ocy-acc torch. I have also heated the metal then apply plumloy. Still the same rough surface. I am thinking of tinning it then apply plumloy. Any ideas? Also what it the best way to sand plumloy? Thanks tbreaden
I have found that after you have a good flash copper base of at least 30- 60 minutes, then applying the plum-loy with a brush to fill the pits and heating with a propane torch from the opposite side, to the point that it forms a black residue that can be wiped off using a damp cloth. You can then sand with wet/dry sandpaper 120+ grit and then buff out the sanding marks that you have created. Once this is done you can acid copper the part and buff it out to a mirror defect free finish.
-- Craige Brooks Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm |
