Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Plating Pot Metal
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
Old 04-09-2007, 01:23 AM
Lt_Dan's Avatar
Lt_Dan is on a distinguished road
Default Copy Cad over zinc question
I have two carbs off of a vintage British motorcycle that are zinc die cast/pot metal. Can I use the Copy cad system over this material and can I use the brightener or blue chromate with Copy Cad over zinc die cast. One more question if I can put Copy Cad over zinc die cast/pot metal and changed my mind and wanted Electroless nickel can this be done.
LT_Dan
Old 04-10-2007, 11:11 AM
Lt_Dan's Avatar
Default Re: Copy Cad over zinc question
Maybe I posted this in the wrong section, I don't know, I am new at this. Any help/answers? ? ? Do I need to reword the questions? ? ?
LT Dan
Old 04-10-2007, 10:02 PM
Zinc Plating Guru
Lt_Dan:
Sometimes you need patience. Not everyone visits here every day.
Yes, you can zinc plate die-cast carb bodies. Depending on your carbs particular mix of pot metals, you may be able to color chromate it w/out plating. If the zinc content is high, it may chromate well. If it's low, you'd need to plate it first.
Unless your carb was a shiny bright color to begin with, you may not want to use brightener. I tried to, and it was far too shiny:
I don't know anything about electroless nickle, but it sould be do-able.
Sean
Seans Zinc Plating page
Old 04-15-2007, 11:19 PM
Lt_Dan's Avatar
Thank You for the reply.
Sorry for the lack of patience.
Are those two plugs in the lower center of the carb added after plating or are they made of something that did not plate? Lead maybe?
LT_Dan
Old 04-16-2007, 10:21 AM
Zinc Plating Guru
They are the original plugs, aluminum I think. I masked them off w/"mask it", as I didn't want them to plate.
This is a carb part I'm experiment with, to find what does & doesn't work.
Sean
Copy Cad Help (Power Supply Problem ?) Rab Electroplating Questions 13 03-23-2007 11:57 AM
New Copy Cad formula Question shaley Electroplating Questions 0 03-09-2007 08:41 PM
Can you use zinc wire for anode in Zinc Plating (copy cad)? ms042180 Electroplating Questions 2 12-23-2006 02:46 PM
Copy Cad / Zinc Trouble Rab Electroplating Questions 2 05-09-2006 09:04 PM
How dark is the olive drab? + zinc question. jbvan Electroplating Questions 4 02-01-2003 01:12 AM
Powered by vBulletin® Version 3.7.0
