| Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them. |
aluminum oxide it one of the best (less dust and longer life) I have heard 180 grit is good but I have not used it. I cannot find any local, All I can find is 80 grit. I have used 80 with pretty good sucess. I am also looking for the best to remove chrome and clean pits in pot metal.
I've been searching for a media blaster. There are a lot and most are reasonably priced too. BUT what I find now is that I need to buy a 5 HP compressor to run it. Have you priced 5 HP compressors lately? Before I set up the new Triple Plate kit I received today I'm going to have to try to figure out how to clean the pits of my pot metal bezels without media blasting. This is getting pricey ! Thanks again TB ! |
Maybe you can find a local company to do your blasting for you. because you have to get the chrome off and clean the pits out. then I use the MetalX stripper to strip the nickle,you have to heat this to 130-150f with aggitation. It gets you down to the copper and it will eliminate alot of pits (and work)that are not into the pot metal.. Then you can try the pickle #4 it is a deoxider and activator for zink die cast. Todd Breaden
less dust, you got to be kidding, all i see is a cloud of dust.. switched to glass bead, leaves a good finish and about no dust at all
I think I have to agree with you donafams. I'm using aluminum oxide now and my garage is a mess with the dust. I'm using it without my shop vac hooked up to it but still I'm going to give glass bead media a chance next time. Just the thought "sounds" cleaner. Thanks for the suggestion! |
| info on blast media | Blademan | Powder Coating Questions | 7 | 05-18-2007 07:58 PM |
| Blast media??? | 3000gtvr4 | Powder Coating Questions | 2 | 06-19-2006 11:14 AM |
| What type of media to use? | Tito | Other Metal Finishing Questions | 1 | 05-27-2004 09:10 PM |
| Blast Media info | Bud | Powder Coating Questions | 4 | 05-05-2004 11:21 PM |
| where to buy blast media? | joenintiesc | Other Metal Finishing Questions | 2 | 04-12-2004 09:14 PM |
