Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Plating Pot Metal
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
  #11 (permalink)
Old 12-14-2003, 12:19 AM
Moderator
bhhodges is on a distinguished road
Default proper cleaning
whatever base your plating too dosent really matter except for maybe potmetal. what has improved my copper and nickel plating by far is proper cleaning of the base without a doubt. i use electrocleaner in a stainless steel stock pot with the stock pot being the anode and this way i can clean each item i plate 360 degrees all the way around instead of maybe an anode in the front and back or whatever. since i changed to doing this i never have falied a water breat test ever. have i had bad results in the plating tank?? i sure have---but not that many ----and the ones i have had can be traced back to usually to much voltage or amperage while plating, so dont blame a new batch of plating solution, my opinion would be to look at proper prep and cleaning.
bill
  #12 (permalink)
Old 12-14-2003, 08:59 AM
Moderator
Default Plating with Copper Flash (Alkaline Copper)
Bill's approach mirrors mine exactly. Cleaning is everything. The most important thing is passing the waterbreak test.
Ken
  #13 (permalink)
Old 02-27-2007, 11:41 PM
wayzata
Default Re: Flash Copper Problem
Ken,
Thank's for your good information on the flash copper. Everything you said sounds like good stuff. I am getting ready to order the flash copper material from Caswell for the first time, so your advice is very timely.
Can I ask how you determine if you have under 60ma/sq.in.? What kind of reostat set up are you using? Do you use a six vlt system to plate with? Is the copper a little more forgiving than the copy chrome?
Phil
flash copper on pot metal newview Electroplating Questions 2 11-18-2005 07:14 PM
Keep getting blisters in flash copper plating...HELP gtabadboy Electroplating Questions 7 11-17-2005 08:19 PM
nickel copper flash kit keala Electroplating Questions 1 08-25-2005 09:30 AM
Plug-n-Plating Nickel over Flash Copper JoeMig Plating Pot Metal 0 07-22-2004 12:13 PM
Newbie ? on copychome and flash copper? KevinW Plating Pot Metal 3 11-08-2002 12:49 PM
