| Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them. |
Yellow chromated zinc plate - see http://www.caswellplating.com/kits/zinc.htm
Carbs are usually zinc die cast.
If you want a shiny surface, you need to polish first. If you want a satin finish, glass beading works well. Either way, as long as the part is clean, zinc will apply readily over existing zinc.
A good rolling boil seems to work out the beads pretty well. If the part has taken on beads, you will get a fine sandy layer on the bottom of the degreasing pan within a minute or two. The sandy looking stuff is cracked beads. I like to lift the part out and let it drain several time at different angles to rinse the beads out of the jets. Seems to work better than trying to blow out each jet individually with high presure air. Keep us posted on your results. There are a few of us working with carbs. |
If I have a good layer of zinc for the chromate to adhere to I just activate with an acid dip for a few seconds. If the zinc does not look good I put down a thin layer of zinc before the new chromate.
Dave |
| Holley Carb plating | scjmach | Plating Pot Metal | 2 | 08-11-2007 01:08 PM |
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 09:11 AM |
| Nickel bath inexplicably quits plating | jackf | Electroplating Questions | 5 | 01-25-2005 09:55 PM |
| A couple carb plating questions | KenL | Plating Pot Metal | 0 | 01-23-2004 08:34 PM |
| plating and size power? | chromo | Electroplating Questions | 7 | 01-18-2003 02:52 AM |
