Go Back   Caswell Inc. Metal Finishing Forums > Electroplating Questions > Plating Pot Metal
Connect with Facebook
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
Closed Thread
Old 05-04-2008, 07:36 AM
Homba is on a distinguished road
Default Copy Cad Zinc Blackener
This is my first post on the forums, so Hi to you all.
I'm having difficulty achieving a black finish on a zinc workpiece. It was previously phosphated, and I have stripped it back to the metal using Birchwood Casey Blue and Rust Remover (Sulphuric and Phosphoric acid based), and steel wool. I have previously treid using Birchwood Casey Aluminium Black, which does impart a truly black finish to it, but often turned out patchy, as you do not get enough solution in the bottle to immerse the part. So I bought Copy Cad Zinc Blackener, and following the instructions, made a 10% solution. I thoroughly scrubbed the part using the Blue and Rust remover and steel wool, and then rinsed it thoroughly and placed it into the Copy Cad solution for 5 minutes, agitating the part. I then removed it and rinsed it throughly, and left it overnight. I even tried degreasing it after rinsing it - the finish I get using this method is only a dark brown, even when I seal it using WD40 - what am I doing wrong? I'm convinced that I would get a nice deep black if I sandblasted the part with aluminium oxide grit, but I don't have acess to a gritblaster of any kind. Can anyone recommend a better way of pre-treating the metal to get a better finish please?
Your help will be very much appreciated.
Gary
Old 05-05-2008, 07:00 AM
Default Re: Copy Cad Zinc Blackener
I have tried to blacken this piece 8 times, thoroughly stripping it back to the shiny metal each time beforehand, but still it only turns out brown, and now I have used up all the concentrate.
I have since noticed from other posts on this forum that the instructions are wrong, and that I should be mixing the solution 1 to 4. The container I have says 'Copy Cad & Zinc Blackener New Formula' and the label advises to mix 1 part to 9 parts of distilled water. Since I live in the UK I bought it from Caswell Europe - would they be willing to provide me with a replacement container of concentrate?
Old 05-08-2008, 10:57 AM
Zinc Plating Guru
I don't use the blackener on anything but pure plated parts, so this may not eb entirely applicable, but ...
What is your "zinc workpiece"? pure zinc or a die-cast alloy? The blackener needs a high percentage of zinc content.
I'm not familiar w/the Birchwood products, but if it's got phosphoric acid, you may be re-phosphating the part, preventing the blackener from reacting with the zinc.
Why not use just 5% sulphuric as recommended in the manual?
I think you need to better identify the metal alloy. If it doesn't have high zinc content, it just won't work as expected.
Sean
Seans Zinc Plating page
Old 05-17-2008, 05:37 PM
Hi.
Thanks for your reply. The workpiece I have is a die-cast zinc-alloy (95% zinc). When I apply the acid stripper, It phosphatest he surface to a dull grey. I then vigorously remove the phosphating by scrubbing with coarse steel wool back to bright zinc. Here is the MSDS for the stripper that I am using. http://www.birchwoodcasey.com/sport/.../16125-BR1.pdf
I cannot use sulphuric alone as it unfortunately isn't available here in the UK.
Old 05-18-2008, 06:02 AM
KCV6's Avatar
Moderator
Sulphuric should be available as 33% from your local car battery supplier. just mix 30 to 60 mill per litre of water to get bright dip.
Old 05-19-2008, 08:10 AM
I'll see what I can do. You used to be able to buy it from these places but they stopped it a long time ago due to people misusing the acid.
Old 05-19-2008, 10:34 AM
KCV6's Avatar
Moderator
Yep, I understand, much the same here, I had to explain what I use it for, kinda helped that I had my work ID on at the time. Possibly try a chemical supplies place and ask for 10% sulphuric in a 5 litre container or 20 litre cube. Far less likely to ask questions then.
Cheers
Mark
Closed Thread
Copy Cad over zinc question Lt_Dan Plating Pot Metal 4 04-16-2007 11:21 AM
Can you use zinc wire for anode in Zinc Plating (copy cad)? ms042180 Electroplating Questions 2 12-23-2006 03:46 PM
Zincate Mikuni HSR42 carb and use zinc blackener borgen Electroplating Questions 1 01-18-2005 07:39 PM
Copy Cad kit - blackener and yellow cad durability problems Broke Electroplating Questions 11 01-09-2005 11:19 AM
Zinc Plate with Blackener carx7 Electroplating Questions 6 08-11-2003 05:16 PM
