Go Back   Caswell Inc. Metal Finishing Forums > Electroplating Questions > Plating Pot Metal
Connect with Facebook
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
Closed Thread
Old 10-26-2008, 11:40 AM
orrin is on a distinguished road
Default removing yellow dichromate
I build and rebuild holley carburetors. Currently my color process is as follows:
*bead blast
*tumble
*dip in pickle
*dip in yellow dichromate
the finish comes out perfect. i guess the pot metal in the carb has enough zinc in it you do not have to plate it first. My question is. Does anyone know of anything i can dip the carb in to remove the existiong yellow. the bead blasting and tumbling is not practicle all the time. i tried muratic acid and it got very violent and hot. Also the carb turned really black. It did remove the yellow though. But i still had to blast it.
Old 10-26-2008, 10:43 PM
KCV6's Avatar
Moderator
Default Re: removing yellow dichromate
10% sulphuric or 1% nitric will remove the chromate and do far less damage to the underlying pot metal. It depends on the condition of the gold chromate. You will still need to scrub the item after. Bead blasting is still the best method I find.
Cheers
Mark
Old 10-26-2008, 10:52 PM
CarWiz's Avatar
Caswell Platinum Member
Yeah, the HCL will react violently with the zinc in die cast metals (pot metal). You might try a very weak solution of HCL or try vinegar. But remember, DO NOT ADD WATER TO ACID--Add the acid to water.
Closed Thread
What is dichromate and how is it applied?? MrPontiac Electroplating Questions 4 07-15-2008 05:03 PM
Yellow Tint CuloMalo Powder Coating Questions 5 03-13-2007 12:16 PM
ski doo yellow? upersleder Powder Coating Questions 3 12-05-2006 07:40 PM
Dichromate jrow Electroplating Questions 4 09-12-2005 11:00 AM
"Yellow Dichromate, Yellow Zinc" Rickc Electroplating Questions 1 01-21-2004 07:22 PM
