Go Back   Caswell Inc. Metal Finishing Forums > Electroplating Questions > Plating Pot Metal
Connect with Facebook
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
Old 11-17-2008, 03:16 PM
BVKLLP is on a distinguished road
Default how can you tell pot is pot metal?
what are the tell tale signs? if someone handed you a piece of steel and a piece of pot metal how could you tell?
Old 11-17-2008, 04:43 PM
FigureLLC's Avatar
Caswell Platinum Member
Default Re: how can you tell pot is pot metal?
if it's cast, too heavy to be aluminum, and isn't magnetic, it's likely pot metal. that's the best i got...
Len
Figure Finishing
www.FigureEngineering.com
866-900-4949
Old 11-19-2008, 02:29 AM
KCV6's Avatar
Moderator
Pot metal looks like cast aluminium but usualy has a strange pattern in the finish with some parts looking darker than others almos crystaline like. this is the various metals used not mixing properly. take a look at a bare part on a die cast toy car, you will see what I mean.
As FigureLLC said above, see if it is magnetic. If it is it is steel or iron or one of the lower grades of stainless.
If it is not magnetic, place a drop of 10% muriatic acid on a clean part of the bare metal. If it is aluminium or pot metal it will start to fizz. after about 10 seconds wipe the surface off with a wet cloth thoroughly. if the patch that was fizzing has gone shiney and clean it is aluminium. If it has gone dark grey to black in colour it is pot metal. The zinc in the pot metal will turn dark grey to black. Make sure you remove all the acid or it will just keep eating through the zinc.
Cheers
Mark
Old 11-19-2008, 12:39 PM
FigureLLC's Avatar
Cheers
Mark
awesome piece of info. thanks!
Len
Figure Finishing
866-900-4949
lab metal pickleboy Electroplating Questions 2 06-29-2005 04:15 PM
How can I age metal? MattAnonymous Metal Polishing Questions 2 05-23-2004 11:43 PM
Pot Metal harold Metal Polishing Questions 1 08-04-2002 10:41 AM
Pot metal Buddysan Other Metal Finishing Questions 2 07-26-2002 07:46 PM
metal ID dburke26 Electroplating Questions 1 01-27-2002 10:16 PM
