Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Plating Pot Metal
Plating Pot Metal Plating this troublesome metal can be very challenging. If you have questions, tips or tricks about plating onto pot metal (zinc diecast), this is the place to post them.
Old 07-06-2003, 08:55 PM
neil
Default pot metal or aluminum
I'm having a problem distinquishing pot metal from aluminum to me the part I have looks like aluminum its from a japanese motorcycle.I put it in the Zincate and it started to react violently when I dipped it.Also did it when I put it in pickle #4 is it pot metal?.If it is what is the procedure for pot metal(sp degreaser-sandblast-pickle #4 and then flash copper?). I tried zincate then flash copper but I'm having a problem with lifting in certain spots(sandblast-zincate-flash copper) . Do you think I should zincate then strike coat with nickel then copper?.Thanks for any help.
Old 07-06-2003, 11:20 PM
tgoode
Is it a primary case? It may be a magnesium alloy
Old 07-07-2003, 11:52 AM
mcaswell's Avatar
Caswell Inc Founder
To find out if it's pot metal, drop a drop of acid on it in an inconspicuous area. If it bubbles and reacts with the acid, it's pot metal. Aluminum won't react.
You should stop putting these parts in all these different solutions until you find out what they're made of.
To plate pot metal, degrease and plate with Flash Copper.
To plate aluminum, zincate then plate.
Have A Web Site?
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Please define "die casting" metal. edclark Plating Pot Metal 2 11-22-2004 12:51 AM
Annodizing aluminum auto a/c metal lines acsource Anodizing Questions 1 11-24-2003 11:49 PM
Pot Metal Electroless Nickel - Suitability as finish tgoode Plating Pot Metal 6 06-17-2003 07:01 PM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 01:19 PM
