Old 07-22-2003, 09:14 PM
04sp500
Default Aluminum Blasting
Can you blast aluminum with glass beads only?
Old 07-22-2003, 09:23 PM
There are many types of media that work just fine, depends on your desired outcome and strength of the part.
Old 07-22-2003, 09:26 PM
04sp500
Doing a set of four wheeler rims. Mainly just cleaning up and preparing for powder.
Old 07-22-2003, 09:35 PM
Slag will work well for your application and it's cheap.Beware of media that contains silica, extended inhalation of this causes silicosis<-- very nasty lung disease.I stay away from really coarse media, it's faster but causes more metal removal.
Old 07-23-2003, 11:06 PM
Wkillgs
Glass beads work well on aluminum, especially if you will be top coating with a clear. It gives a nice sheen to the part without changing the surface too much. I've been using silicon carbide, as it's more agressive, which works really well on rusty steel or iron parts. Also seems to last longer in my blast cabinet than glass beads. I only use silica sand outdoors on large parts like fenders or frames.... using a pressure blaster. Sand gets very dusty, and as Dale mentioned, it can be hazardous to your health.
Walt
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Do you have to use flash copper to plate aluminum krsimulis Electroplating Questions 1 07-27-2004 02:32 PM
Cleaning Oxidized Aluminum With Sand Blasting Media? freematt Other Metal Finishing Questions 2 02-23-2004 03:22 AM
Will abrasive blasting get rid of aluminum casting marks? liem921 Metal Polishing Questions 1 10-11-2003 07:15 AM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 02:19 PM
