Results 1 to 9 of 9
Thread: Creating a current for high temp plastics
  1. #1
    John_Henry is offline Newbie
    Join Date
    Apr 2009
    Posts
    20
    Default Creating a current for high temp plastics
    Had a quick question,
    If I am powder coating high temperature plastic automotive parts, like intake manifolds, etc..., will there be enough current for the powder to cling to the part or will it resist the current because of it's polymer base?
    The reason I ask is due to the fact that I have seen some plastic intake manifolds done, but couldn't figure out what current they are using or how the process was preformed.
    Thanks guys
  2. #2
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    Default Re: Creating a current for high temp plastics
    no, it can't effectively be grounded. stick your part in the oven at 225 or so then pull it out and shoot it hot. the powder will melt on contact and stick that way.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  3. #3
    ty1854 Guest
    No you will not be able to do them cold as the plastic is a insulator and the powder will not be attracted to the part. You must hot flock on these kind of parts. That being said if you happen to have the Columbia Coatings Hyper Smooth with the Multi Coat tip then you can do them cold no problem. That is the only way I know of to do them cold. just be careful when hot flocking or you will get runs if you apply to much powder.
  4. #4
    Join Date
    Apr 2009
    Posts
    20
    Sweet,
    Thank you again gentlemen for your wise words.
  5. #5
    j4str is offline Amateur Metal Finisher
    Join Date
    Mar 2009
    Posts
    98
    Quote Originally Posted by ty1854 View Post
    I watched that video on the hyper smooth mulit coat nozzle and i just think its a gimmick. I can't see how it could disperse THAT much different than any other gun. Anyone have any first hand experience?
  6. #6
    ty1854 Guest
    Quote Originally Posted by j4str View Post
    I just happen to have first hand experience and I promise you that it is no gimmick! If you happen to be around NW Georgia you can come by my shop and I will be happy to show you what it will do (that offer stands for anyone else also). It absolutely does everything as advertised. It will lay powder on ANY material at room temp. no hot flocking required. I have even coated tile for a shower with this attachment. It lays the 12th coat on just like the 1st! I just cant say enough about this tip it makes life so much easier for me.
  7. #7
    o1racing03 is offline Amateur Metal Finisher
    Join Date
    Jun 2008
    Location
    Dawsonville,Ga
    Posts
    89
    Where are you located?
  8. #8
    ty1854 Guest
    Quote Originally Posted by o1racing03 View Post
    I am in Menlo, Georgia. It would be about 3-4 hours from you location I believe. If you are ever out this way feel free to drop in anytime.
  9. #9
    defed is offline Amateur Metal Finisher
    Join Date
    Mar 2006
    Posts
    185
    i know this isn't a hypersmooth thread, but i have to concur w/ ty. i haven't used it as much as he has, but i have put 8 coats on a wrench, cold, easy. i messed around w/ some other materials to see if it would stick (didn't bake any of them) and it seemed to stick to all.
    not sure how it works, but i have an idea from studying the nozzle closely. it doesn't look like much, that's for sure.
Thread Information
Users Browsing this Thread
  1. High temp powder
    By goincrzy in forum Powder Coating Questions
    Last Post: 02-19-2009, 06:22 PM
  2. high temp. cement?
    By Canute7 in forum Oven Building Forum
    Last Post: 06-14-2006, 02:00 AM
  3. colored high temp?
    By mtnbiker in forum Powder Coating Questions
    Last Post: 12-21-2005, 09:00 AM
  4. high temp- how high? - will it burn?
    Last Post: 09-26-2005, 11:47 PM
  5. Can I use VHT high Temp with Krylon High temp radiator paint
    By magnus in forum Other Metal Finishing Questions
    Last Post: 05-03-2003, 11:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
