Results 1 to 6 of 6
Thread: Rust through powder after only 2 months
  1. #1
    moxieboy is offline Newbie
    Join Date
    Mar 2009
    Posts
    37
    Default Rust through powder after only 2 months
    I had these 3 deck railings done. I had to send them out to a local powder coater because of the over sized 10 foot lengths. After just 2 months outside I received a call telling me that he has rust coming though many areas. My customer is not happy. I noticed that there are tiny pinholes from what appears to be too much powder flow? What are your opinions? the railings had to be chemically stripped and then blasted (so they claim). They did not prime these but said they hit them with two hits of white. It looks like they put it on too think and it bubbled making pin hole exposed allowing moisture in and making it rust. Here are some images. What would you do to fix it so this doesn't happen again?
    to see all 12 images click here:
    Image hosting, free photo sharing & video sharing at Photobucket
  2. #2
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: Rust through powder after only 2 months
    Those would be going back to the place that coated them. No sense in letting it slide. If you did the work, you'd cover it no problem. Poor quality is poor quality. Send 'em back.
    EMAIL scott@scottrodspc.com
  3. #3
    nomoreusmc is offline Newbie
    Join Date
    Mar 2009
    Posts
    5
    yeah, those should have been phosphated
  4. #4
    Harleydad's Avatar
    Harleydad is offline Metal Finishing Guru
    Join Date
    Dec 2006
    Posts
    833
    Quote Originally Posted by nomoreusmc View Post
    and primed.
  5. #5
    Join Date
    Mar 2009
    Posts
    37
    Thanks for the advice... The painter said it was due to the residue left behind from chemically stripping them. I think this is a bunch of BS. I will tell them to phosphate and prime first. Any recommendations on a primer?
  6. #6
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by moxieboy View Post
    Zinc Rich Primer would be my best advice. But,.... I would also advise to outgas before the primer, and a second cleaning.... Phosphating after second cleaning.
    1 chem stripper
    2 outgas,.... at 50* above cure temp of coating
    3 Phosphate
    4 zinc rich primer - FOLLOW THE DIRECTIONS ON THE PRIMER CLOSELY
    5 final coat.
    The pieces you showed should have been done similarly to that in the first go-'round. If all else were done properly, you might be able to skip the primer,.... but seeing as you've already had bad results, I'd recommend it next time around.
Thread Information
Users Browsing this Thread
  1. Simulated Rust Powder Coat
    By Shortie in forum Powder Coating Questions
    Last Post: 05-01-2008, 07:03 PM
  2. Is it rust, or brass, and what do I do?
    By HowdeeDoodee in forum Metal Polishing Questions
    Last Post: 01-03-2008, 10:46 AM
  3. rust remover
    By ublinkd in forum Powder Coating Questions
    Last Post: 11-03-2006, 08:57 PM
  4. after nickle plating rust
    By chipmetal in forum Electroplating Questions
    Last Post: 05-25-2006, 10:55 PM
  5. rust remover??
    By dmend in forum Powder Coating Questions
    Last Post: 04-21-2006, 10:27 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
