"I'm your huckleberry" - Doc Holiday "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." -Benjamin Franklin |
I Agree it does look like a bad ground, but its still a 22 gauge wire thats firmly attached to the bare metal hole. Should I really need a large half inch by half inch square area to properly ground it.
Ive tested my power outlet with a ground fault tool and they ARE grounded. Did that when I was trying to do the same with my chicago gun. Ive lowered kv to 15-25kv (<1/4)as stated on the gun. Shooting from from 5-8 inches, pressure tried between 5 and 12 psi. I think Ill try with a OVERKILL ground. Like clip right on bare metal, shooting first coat, then die grinding to bare metal for second coat |
I did manipulate the part after first coat. first coat was applied a week ago, Ive touched it with my fingers quite a lot. I do not think it could mess with anything before cure. Sure Id expect weird stuff after cure, like fish eyes, but static should still be attracted to it when shooting it cold. That's just my guess
Could it be that im using too little powder in the hopper? Maybe its not charging the powder enough because of it. I refused to hot flock, Especially with a gun that shoud easily do 3 coat cold. Hot flocking is messy, and on a thin part like this it cools too quickly. Plus hotflock that pearl and metal flake would make it a paint to get a even consistant looks. Id end up with darker spots and uneven flakes . |
You don't have to hot flock ANYTHING if you do something is wrong somewhere. Take a new test panel and shoot it with a powder and cure it. After it cools apply a second coat to it I guarantee it will go on with no problems. You should have wiped down that part with denatured Alcohol before you shot it cause touching (bare hands) it before coating WILL cause attraction issues if the oil on your hand or some other contamination gets on the part. If you are going to try and trouble shoot you need to eliminate all the variables you can. That means you need to get a new panel and note your prep methods, gun settings, and cure schedule that you are using. This way if something happens on the test panel you can pin point the issue more easily. If I were a betting man I would say bad ground or surface contamination. Anyway shoot a blank test panel and get back with us, good luck!
Ive just done another test. I tried with other powders not from pbtp, just in case.
Cleaned up and grounded straight with gun clip ![]() First; Xtreme Chrome tgic shot at 80kv ,shot at 8-12 inches, came out great (slight OP as always) fully covered:
Next I tried 24-30 inches , with lots of powder, all the way down to barely any power and it went all the way to this.
juuuust slightly better. ![]() Cured: Note the square again ![]() You can see there wasnt enough candy purple everywhere there was chrome underneat. I did not touch the part on any area but the pointed end where I grounded for the candy purple, a place im ignoring in the pics Hope this helps you see whats going on. |
I just watched a video of the same gun doing a second coat, mine does not work as good with the exact same settings. It's like their 2nd coat goes on as easy as first coat, just with lower voltage.
Probably something wrong with my ground. My budget ground fault detector said its ok, but it does not give a value. I'll have to find an electrician with the proper equipment to read ground resistance, should be under 25 ohms, under 5ohms being perfect. I work with microcontrollers, I dont have any power diagnostic equipment such as these. Might have ground , but a high resistance one. Im starting to get ****ed...
