Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Yellow clear coat please help
  1. #1
    ng8264723 is offline Newbie
    Join Date
    Oct 2006
    Posts
    19
    Default Yellow clear coat please help
    I read this post and usuallty do it this way:
    the cure time starts when the part has reached that temperature. It may take 30 mins to reach the temp, depending on the size of the part or density. You should get a IR thermometer and this way you can check the part temperature itself. You may need the part in the oven for 45 mins just to get a cure temp of 380 degrees for 10 mins. Heat up depends alot on the amount of "power" your oven has to emit BTU's into the oven chamber itself
    I did it the way he mentioned. I then let it cure foir 15 minutes and it turned yellow. I'm now stripping it and will try again tomorow. Any advice?
  2. #2
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Default Re: Yellow clear coat please help
    is your ir thermometer accurate ? is the part too close to the elements?
  3. #3
    o1dakota440's Avatar
    o1dakota440 is offline Newbie
    Join Date
    Aug 2008
    Posts
    11
    in my past experiances yellow clear means that you cured at too high of a temp.
  4. #4
    Join Date
    Oct 2006
    Posts
    19
    The temp was a little off maybe 20 degrees. Is that enough to yellow it?
  5. #5
    Harleydad's Avatar
    Harleydad is offline Metal Finishing Guru
    Join Date
    Dec 2006
    Posts
    833
    Quote Originally Posted by ng8264723 View Post
    Yes it is.
    What clear are you using and what are the cure instructions for the powder. You may also want to put an oven thermometer in your oven to be sure temp is close to what the oven is set at.
    What powder did you clear over?
  6. #6
    Join Date
    Oct 2006
    Posts
    19
    I used the caswell high gloss with a additive ti kill the gloss over bare alum
  7. #7
    baz
    Join Date
    Feb 2006
    Posts
    822
    in your first post you state (45 min. to reach temp plus 10 mon at 380 f )
    if you are off 20 degree on top of that . then yes it is enough to cause the yellowing of the clear.
    when i do clear coats i stay below 375 PMT at all times .
  8. #8
    Join Date
    Oct 2006
    Posts
    19
    I will check but I think it said 390
  9. #9
    baz
    Join Date
    Feb 2006
    Posts
    822
    even if it says 390 on the can you should stay below 375 .
    you should begin by making a few tests to see how accurate your readings are.
    do like harley dad says and try to put a oven thermometer in there , take a few different readings in different places in the oven if its a larger oven .
    if it s a smaller oven make sure your part is not too close to the elements
    you did mention that you were working with polished aluminium .
    ir guns do not give an accurate reading on shiny items. the ir rays bounce off the part
  10. #10
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    i generally cure clears at 350 for an extended cycle. the only one i've had a problem with browning was an nic matte - i think - clear. caswell's seems to be fine at 400.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
Thread Information
Users Browsing this Thread
  1. Which clear coat?
    By benherr in forum Powder Coating Questions
    Last Post: 03-02-2009, 09:55 PM
  2. Clear Coat
    By Luck_E in forum Powder Coating Questions
    Last Post: 04-26-2008, 03:04 AM
  3. Clear coat????
    By JeffL in forum Powder Coating Questions
    Last Post: 05-05-2007, 02:57 PM
  4. Clear Coat - What to?
    By itsallgood in forum Powder Coating Questions
    Last Post: 02-25-2007, 08:10 AM
  5. second coat....and clear?
    By bravo3430 in forum Powder Coating Questions
    Last Post: 01-31-2006, 09:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
