Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Old 07-04-2009, 05:35 PM
j4str is on a distinguished road
Default prep aluminum after b17?
What do you guys do? It seems like blasting is the only thing that takes the black sut off. But it seems like there should be something easier
Old 07-04-2009, 07:29 PM
ty1854's Avatar
ty1854 will become famous soon enough
Default Re: prep aluminum after b17?
After I strip the part with B17 and rinse it off I quickly blast it to put a good profile on the metal. I then wash the part with soap and high pressure water to remove any contaminates left by blaster. After that I apply my iron phosphate and rinse with low pressure water, then it is off to the oven to dry/out gas. I use this process everyday and it has yet to let me down.
"I'm your huckleberry" - Doc Holiday
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." -Benjamin Franklin
Old 07-04-2009, 08:58 PM
And if you had to restrip it, you would do all that again everytime?
Old 07-05-2009, 12:27 AM
ty1854's Avatar
Yep do I the same thing every time. It sounds like a lot but I can do it very quick as I have a system I am used to. Also I do several different parts at once to make it more efficient.
Aluminum Prep chcustom Powder Coating Questions 1 01-29-2009 07:59 AM
Deburring wheel to prep cast aluminum? WoodMotorsports Metal Polishing Questions 5 02-28-2008 01:03 AM
cast aluminum prep. boston_jake01 Powder Coating Questions 3 11-09-2006 06:28 PM
Aluminum prep for chrome plate jm Metal Polishing Questions 1 02-02-2004 01:24 AM
Aluminum Wheel prep and polish patrickzeus20 Metal Polishing Questions 2 03-04-2003 01:00 PM
