+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Looking for Sand blast media mix and sizing.
  1. #1
    Default Looking for Sand blast media mix and sizing.
    Hello I just invested in a Sand blasting cabinet and I'm not sure what the best media is to use. I was thinking about using a Aluminum Oxide and Glass bead Mix but I see they sell a medium and a Fine sizes. What would be good for the powdercoating?
    Also how often do I need to change the media (Hours of use) And how often should I clean/filter the media? And where can I buy the filters?
    Thanks
  2. #2
    Join Date
    Nov 2005
    Posts
    945
    Default Re: Looking for Sand blast media mix and sizing.
    what cabinet and compressor do you have?
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  3. #3
    Join Date
    Jun 2008
    Location
    Dawsonville,Ga
    Posts
    89
    In a cabinet you would probably want grits in the 80 range, the finer the better so you dont end up with too aggressive of a profile. You just want your part to have a "tooth" to grab onto. Change it when you notice the performance dropping. And you should only be blasting at about 65-75psi, this will make your media last longer by not smashing the chit out of it at 120psi. Theres no need to mix medias.
  4. #4
    I have a small 24x 15 blasting cabinet and a compressor that meets the 5cfm at 100psi not the best but it works well. I used some play sand just to try it out to see if it will hold up to the cfm at 120psi, 100psi ,90psi ,and 80psi and 70psi but the 80psi seems to work the best.
    I was asking about the mix because I found somewhere that for powdercoating someone was recommending mixing aluminum oxide and glass bead and had used that for a long time and liked the outcome a lot it made the job go faster but had a good finish.
  5. #5
    Join Date
    Jun 2009
    Location
    Bath NY
    Posts
    13
    We use Starblast media. Very fine product that does not wear out very fast.
    We change it after it turns to dust and is collected in out dust filters.
    Costs about $15.00 a bag, much better than play sand
    kris
  6. #6
    Quote Originally Posted by KRISG View Post
    kris
    Thanks for the info on the starblast seems like good stuff. What grade should I get of the starblast? I see there is a ultra and XL or a link would be cool
    Thanks
  7. #7
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    727
    kris
    The thing to do here,... would be to tell where one might get the stuff also....
    EMAIL scott@scottrodspc.com
  8. #8
    Quote Originally Posted by SCOTTRODS View Post
    The thing tio do here,... would be to tell where one might get the stuff also....
    haah that's not a prob google is a great thing now a days and a easy way to shop around for the best price or a location close to home for fast shipping since he/she may be across the county from some. But yea it could help
  9. #9
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    727
    Quote Originally Posted by TwistedEvo8 View Post
    I was giving a suggestion to the OP. It is good to include where one acquires someting if they offer up the suggestion.... that is my direction.
    I did the search myself as soon as I saw it, but didn;t see any 15 bucks a bag stuff, so I thought maybe the OP would fill us in.
  10. #10
    Well I found a site but im not sure of the media size/grade i need but here is a site i found.
    Link to Starblast
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. where to buy blast media?
    By joenintiesc in forum Other Metal Finishing Questions
    Last Post: 03-16-2010, 06:38 PM
  2. Blast Media?
    By kg4mon in forum Powder Coating Questions
    Last Post: 05-28-2008, 11:37 PM
  3. Best Blast Media
    By SLOSteve in forum Plating Pot Metal
    Last Post: 10-19-2007, 06:54 PM
  4. Blast media???
    By 3000gtvr4 in forum Powder Coating Questions
    Last Post: 06-19-2006, 10:14 AM
  5. DO NOT blast with play sand
    By mkminoia in forum Powder Coating Questions
    Last Post: 04-12-2004, 07:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
