Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Two colors on a bike frame
  1. #1
    peter61 is offline Amateur Metal Finisher
    Join Date
    Jun 2007
    Location
    Southern N.J.
    Posts
    104
    Default Two colors on a bike frame
    You guys have helped me out many times,thanks.I have a bike frame(not motorcycle) that needs to done in two colors,white and blue,the bike frame is aluminum,what is the best way do go about this?The frame will have 6" of white an then 10" of blue,thats the pattern,I tested a piece of pipe(galvanized) I shot the pipe with white,baked,taped of half of the white and shot with blue,after the second bake the was great but the white seemed to have tape residue ?I tried the the green tape and the copper color tape,should I have not baked the piece with the tape on?Any help would be appreciated,thanks!
  2. #2
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: Two colors on a bike frame
    Quote Originally Posted by peter61 View Post
    When Masking over another coat, cure til the powder turns "wet" looking, pull the part from the oven and remove the tape. This will keep the tape from leaving the residue, and reduces the ridge at the masking line.
    EMAIL scott@scottrodspc.com
  3. #3
    Culbrz is offline Platinum Member
    Join Date
    Nov 2008
    Posts
    2
    After you remove the tape does the part go back into the oven for the remainder of the cure period?
  4. #4
    hammer71 is offline Platinum Member
    Join Date
    May 2009
    Posts
    3
    Yes, pull out after Flow out, remove tape then place back in oven for remainder of cure schedule.
  5. #5
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by Culbrz View Post
    Yes,.... and to add more, The part likely has not reached full cure temp yet, so "Put the part back in for a full cure cycle" is the right answer, as you will have to get the part up to full cure temp still.
  6. #6
    Join Date
    May 2009
    Posts
    3
    TY Scott I should have been more clear on that.
  7. #7
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by hammer71 View Post
    That's cool,.... just wanted the original poster to have NO questions un-answered. Hopefully we got it now. I obviously didn't answer well the first time either..... hence the continued string of questioning.
  8. #8
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    also, make sure the first coat that's getting taped is fully cured, or it'll re-flow and follow the tape giving you wrinkles. after taping, hit the base coat with some grey scotchbrite to give the second coat some bite.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  9. #9
    Join Date
    Jun 2007
    Location
    Southern N.J.
    Posts
    104
    Smile Re: Two colors on a bike frame
    Well I ended up masking the white and then shooting the blue,taping the blue and then shooting the white,the tape I used was a copper colored light weight high temp tape.I then shot the bike frame with midnight clear,hear is a picture.
    Attached Thumbnails Attached Thumbnails Two colors on a bike frame-bike-frame-009.jpg
  10. #10
    FigureLLC's Avatar
    Join Date
    Nov 2005
    Posts
    945
    hells yeah! never woulda known you were asking how to do it! fantastic work!
    so after you did the blue, the white parts were still bare? did that reduce the step or seam between the two?
    Len
    Figure Finishing
    866-900-4949
Thread Information
Users Browsing this Thread
  1. bike frame sizes?
    By atroxr7 in forum Oven Building Forum
    Last Post: 02-24-2007, 11:45 PM
  2. thin areas on bike frame using metallic
    By datadawg in forum Powder Coating Questions
    Last Post: 01-25-2007, 08:42 PM
  3. Bike Frame....
    By KZjim in forum Powder Coating Questions
    Last Post: 12-22-2005, 02:50 PM
  4. Bike Frame
    By Relfn in forum Powder Coating Questions
    Last Post: 05-02-2005, 07:31 AM
  5. Polishing bike frame
    By flyjetta in forum Other Metal Finishing Questions
    Last Post: 10-09-2003, 01:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
