Results 1 to 5 of 5
Thread: What powders to use.
  1. #1
    TwistedEvo8's Avatar
    TwistedEvo8 is offline Newbie Caswell Platinum Member
    Join Date
    Apr 2009
    Posts
    25
    Default What powders to use.
    Hello
    I have a friend who wants his cold side of the turbo painted hot pink... But I do not want to use a normal powder because I'm afraid the turbo will get to hot from a prolonged session of boost and cause the coating to melt. Does anyone here have experiences in this or tried this before? I am going to run my turbo on my car hard tomorrow and check the temps to see how hot it gets. Also Since the hot side of the turbo gets to be glowing red at some points will the heat from that melt the surface of the power coated part? ( The hot side will be ceramic coated aslo)
    Thanks and does anyone know if they make high temp powders in other colors then black and silvers?
  2. #2
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    Default Re: What powders to use.
    i would stick to the ceramic. if he still insists on powder, run the car (under load preferably) and try hitting the cold side with an ir temp gun to find out what it sees temp-wise. i've read a lot of posts about hi-temp powders failing.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  3. #3
    Join Date
    Apr 2009
    Posts
    25
    Well I don't want to ceramic coat the turbo cold side because he wants it Pink... I want to use the normal powder on the turbo because I can get it in Pink... The High Temp powder im sure will hold up.
    Hey has anyone tried to ceramic coat then powder coat over the ceramic with high temp?
  4. #4
    Join Date
    Apr 2009
    Posts
    25
    Bump! Anything
    Need something in the Tri-State Powder coated check out... Backyard Powder Coating
  5. #5
    Unatural's Avatar
    Unatural is offline Newbie Caswell Platinum Member
    Join Date
    Dec 2006
    Posts
    24
    I have used both black cat urethane and solar flat black on turbos for my car and haven't had any problems at all. I have a turbo blanket on the turbine housing, so that keeps the under hood temps down quite a bit, but I don't think it makes much of a difference on the overall temp of the compressor side.
    Wayne
Thread Information
Users Browsing this Thread
  1. anyone ever mix two powders together???
    By corybarta in forum Powder Coating Questions
    Last Post: 04-26-2011, 04:11 AM
  2. Chrome Powders?
    By donafams in forum Powder Coating Questions
    Last Post: 08-05-2007, 05:43 PM
  3. Low temp powders?
    By cordcutter in forum Powder Coating Questions
    Last Post: 04-05-2006, 12:37 AM
  4. 5 New Powders
    By mcaswell in forum Powder Coating Questions
    Last Post: 11-28-2005, 12:15 PM
  5. which powders ?
    By duke in forum Powder Coating Questions
    Last Post: 09-27-2003, 02:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
