Results 1 to 4 of 4
Thread: way to prevent steel from darkening during bake?
  1. #1
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    Default way to prevent steel from darkening during bake?
    i've noticed that steel darkens when baked, even if the temp is kept to 350. is there a way to keep this from happening? do any of the conversion coatings help?
    applications where this would be useful: 1) brushed steel is nice and shiny, then when cleared and baked it darkens to a gun metal color. 2) with some light opaque colors, coverage mistakes are very unforgiving.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  2. #2
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Default Re: way to prevent steel from darkening during bake?
    The different colors by heating are different oxidation stages. If you can stop the oxidation or pre-treat it should stop the transitions. The problem is that most passivation processes themselves change the color and can be destroyed by heat. And, if you're powder coating the steel then heating, the coating itself may provide some transition ions. If I recall, tin and zinc are non-transitional metals. If the steel was flash coated with one of these, it would retain it's color and maintain underlying patterns (dependant on plate thickness of course).
    Does this help?
  3. #3
    FigureLLC's Avatar
    Join Date
    Nov 2005
    Posts
    945
    good info, thanks! interesting you mentioned zinc... today i was looking at a sample piece i did. it was galvanized sheet that i took a brush wheel to, then cleared. the steel hadn't darkened and i was wondering why that piece was different.
    what's it take to flash zinc something?
    Len
    Figure Finishing
    866-900-4949
  4. #4
    CarWiz's Avatar
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Caswell has zinc and tin plating kits. I don't know how large your pieces would be but zinc does take a lot of power to plate--About .14A per square inch according to the book. Tin is about .01A per square inch.
    Caswell Inc. - Copy CadŽ and Zinc Plating Kit
    Caswell Inc. - Bright Acid Tin Plating Kit
Thread Information
Users Browsing this Thread
  1. prevent blueing of chrome pipes
    By PennsyScot in forum Powder Coating Questions
    Last Post: 06-01-2009, 04:01 PM
  2. Bake in a non-gas oven....
    By BottleFed70 in forum Powder Coating Questions
    Last Post: 01-21-2008, 07:41 AM
  3. Will clear PC prevent rusting on steel?
    By quadracer2cool4u in forum Powder Coating Questions
    Last Post: 01-16-2008, 11:41 AM
  4. What Temp for Pre Bake???
    By Noob2PC in forum Powder Coating Questions
    Last Post: 04-16-2004, 11:58 AM
  5. Darkening brass faucet questions
    By jodie in forum Other Metal Finishing Questions
    Last Post: 05-22-2003, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
