You'll notice it right away! There will be bubbles "blown out" through your powder coat. Clean the part well. I wash mine down real well with CRC BraKleen brake cleaner. It destroys grease and oil. Then sandblast it real well. Put in the oven and "bake" at 400 degrees for 15-20 minutes *before* powder coating. This will let the aluminum outgas before you powder coat it. Let it cool, then powder coat like normal. It may not completely eliminate the bubbles in your powder, but it will dramatically reduce them. Good luck!
Hemi-T
