Results 1 to 2 of 2
Thread: Yellow film after rinsing..??
  1. #1
    ozzyman is offline Platinum Member
    Join Date
    Sep 2009
    Posts
    1
    Cool Yellow film after rinsing..??
    Latest Example...Steel Bike frame, Beadblasted and blown off.. Rinsed with HOT WATER... I then pretreat with Columbias' Iron Phosphate using a spray bottle.. Doing this outside with a HOT water hose handy to rinse off the parts... Kinda windy that day so the parts were drying fast..I kept it moist with the phosphate alot...then after the few minutes I rinsed immediatley with hot TAP water... As the wind was drying it I could see yellow film forming in sporadic areas.. I used compressed clean air to blow dry completly = however this yellow film was persistent...
    The Tap water is softend..Country water/farm area but NO rotten egg smell..etc..
    ... Film almost appears to be hard water stain in nature... When dry - I used a white cloth and some of it wiped off onto it....
    I have done steel clutch covers and no staining...Not a windy day so the parts had adequate time to Phosphate..etc..
    Any ideas...??
  2. #2
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: Yellow film after rinsing..??
    Quote Originally Posted by ozzyman View Post
    Any ideas...??
    Possibly Flash Rust. Possibly normal for that particular metal.
    Eliminate the windy issue and phosphate in the bathtub,.... see what results you get.
    I recently saw a discussion thread on another forum that had the same basic issue. It was called "Normal" bny several of the seasoned guys. Doesn't sound normal to me. Sounds like flash rust.
    EMAIL scott@scottrodspc.com
Thread Information
Users Browsing this Thread
  1. Life of yellow iridescent yellow Chromate??
    By MrPontiac in forum Electroplating Questions
    Last Post: 01-31-2009, 03:46 PM
  2. Specifics on rinsing
    By coopduc in forum Anodizing Questions
    Last Post: 08-17-2008, 08:55 PM
  3. Rinsing and the Enviroment
    By need1moretool in forum Electroplating Questions
    Last Post: 02-06-2005, 11:53 AM
  4. Rinsing Process
    By BryanD in forum Electroplating Questions
    Last Post: 12-22-2003, 11:13 PM
  5. Rinsing Of Parts
    By rdanielewski in forum Electroplating Questions
    Last Post: 12-08-2002, 10:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
