It can be done. You might want to consider putting all your colors on as you stated, but don't cure them completely until you get the last color on, then cure it. After which time you would put on the clear, but a regular coat of clear will work. You will have to mask everything as you move through your different colors like painting a car.
LinkBack URL
About LinkBacks
help!!!
